Getting Very Hot!
Guest 40th-edition
driving back from tamworth today the line was getting very hot and not stopping rising so every hill i coasted down and kept her cool, limping it home.
never had this problem before!! but never done a really long trip in this hot weather that we had today.
anyone else have this??
i know intersooler blocks more than half the radiator but never before been this hot!!??
cheers, Azza
https://www.sau.com.au/forums/topic/144362-getting-very-hot/
yeah thats no good, if it does it more mabe water pump is shagged, have seen the blades on a water pump basically perish on an rb30e and it had a similar problem, just hot as all of a sudden. was only when they pulled the water pump out they found the blades on it were non existant
was the clutch fan working?
i'd also check the thermostat.
a good idea when the clutch fan kicks in is to drop back a gear to get the revs up higher. this pulls more air through the radiator. works good around town, you just have to put up with the roar of the fan.
Guest 40th-edition
cheers heaps guys..
i know the water pump is good, got changes 20k ago.
thurmostat is good due to correct warm up and running temps.
i was going to check that little ac electric fan in front of the condencer... see if its working. but it was down the h/way at 100-90 so i didnt think the fans would come into play so much!
the viscus fan is working fine, checked that right away.
do the alloy tank radiators run cooler at all from the standard plastic
ones??
thanks again, azza
i have a just jap cooling pro radiator, and my engine runs between 74-78 degrees, peaking out at 80 - 82 on a hill climb with 10mins of hard driving on boost.....
----could be a head gasket.
Could be radiator needs to be taken off and new end tanks and flush etc., ac fan has nothing to do with it.
Edited by HRthirtyone
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
