I have a fully built rb25det with t66 making 315rwkw on 20psi.full boost at 4800rpm till 7600rpm(stock cams.)
I would like less lag(more response)with more top end,is it possable?
What cams do you recommend to do this or otherwise?(cam gears too?)
Thanks.
what ecu are u using? how well is it tuned? what about the exhaust setup? a t66 is fairly large, but you can probably get some better-ish response out of it, just not sure how much you are expecting? some tomei poncams should drop straight in and give you a bit more zing, i dont think you need cam gears if you throw in poncams
yeah mate its got good exhaust and tuning and runs an ems 8860 with eboost2.
So do poncams come in different stages cos obviously i dont wanna get the set that someone would get for their 250kw stock 25....(or do i ?)
Has some one else done this what changes did the cams make?
Any info is great thanks.
what size rear housing has your turbo got?
options at reducing that before opening the motor?
comparison :
my car - HKS 3040 with 1.12 rear housing and tomei poncams - full boost 5000rpm
friends car - garret gt30 with 0.82 rear housing and STD cams - full boost 5000rpm
doubt its just being HKS that can make the turbos similar with that much difference in rear housing size.
Edited by Craved
