Hey all,
It's time for my pride and joy to find a new home. This car was purchased 3 years ago from my local nissan dealer and has been built up by myself and my b/f over the past few years. The car has been kept imaculate and serviced regularly by ourselves. It's time to make way for a new project and for her to find a new happy home.
Being a well known SA car, it's progression has been visable by all.
Engine:
SR20DET (12x,000) serviced regularly
Hybrid Front Mount Intercooler
Full Stainless Exhaust Technology Turbo back exhaust 3" straight through with single JUNBL dual exit box and twin stainless flutes
APEXI ECV fitted to the above system
Blitz Pod Filter
Transmission: 6 Speed
Exterior:
3 Month Old - Doyle Crash Custom Paint - Mocha Mica (exterior / door seals / trunk / seals and windows removed)
Vertex Kit
Viva Garage Vented Bonnet
Hipposleek Duck Tail Wing
Hand Pumped front guards (all metal - increased by 20mm)
Hand Flared Rear guards (all metal - increased by 40mm)
Work Euroline SL Dishies 18x9 +18 R disk 225/40/r18 fronts and 18x10 -5 O disk 235/40/r18 rears
Tint
Interior:
Matching Recaro Reclinable Seats
Dildo Gear Knob
JVC MP3 Head Unit
APEXI Boost Gauge - mounted in air vent
3 Point Imobilizing Alarm
Suspension:
Silk Road Section RMA8 Coilovers (fronts - purchased new aprox 1000 k's ago)
Yashio Factory Rear Coilovers
Project MU Brake Pads
Asking Price: Mid to High 30's
All offers sent via PM ONLY, we would like this sale to be easy and not time consuming so please no tyre kickers, time wasters, shit posters or "more pictures" askers... sufficient information provided within this post - and as previously mentioned all negotiations to take place via PM
for pics - http://www.nissansilvia.com/forums/s15-SA-...me-t201215.html
https://www.sau.com.au/forums/topic/144393-s15-sa-yes-its-time/
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
