Got some of these gauges for sale:
Smoke series gauges from $39, also have water temp, oil temp, oil pressure, vacuum, volt, ait/fuel ratio gauges and 360 degrees boost gauge, all prices are different.
-Auto Gauge 270 degrees 52mm Boost Gauge(PSI) $39
-Auto Gauge 270 degrees 52mm Boost Gauge(BAR) $39
EL series gauges from $29, also have water temp, oil temp, oil pressure, vacuum and volt, all prices are different.
-Auto Gauge EL 270 degrees 52mm Boost Gauge(PSI) $29
-Auto Gauge EL 270 degrees 52mm Boost Gauge(BAR) $29
Auto Gauge gauge holder to fit all kind of gauges from $13, please leave part number.
Autogauge turbo timer
-Auto Gauge Mini Box Style Auto Turbo Timer $47
-Auto Gauge Pen Style Turbo Timer with Voltage Display $55
*All new in box, come with all necessary hardwares and English installation manual.
*Please try not to PM me unless something personal, just leave a message in this post if you're asking for price or question, I'll get back to you asap, so I can keep this post update, thanks. :(
Edited by cookiebear
  • Replies 61
All PM replyed, and if you've any question please leave it here, and I really perfer not to PM me, I rather answer everyone's questions in here, unless something private, otherwise my post can be lost in 1 day, thanks. :(
  • 4 weeks later...
wraith_skyline, for the smoke series boost gauges, you can get them in bar or psi, they're $39 each + postage, and I have another smoke one which is a 360 degree boost gauge (psi) for $65, same as the one you see in the photo.
lineskee 33, still have your number and all your details, will keep you update when the money arrive, thanks for buying. :)
Hey mate,
have you got anymore of those Smoke series boost gauges $39. i assume its the one in the first attached pic? just a question..how much do they read up to? i assume 30psi? and for anyone who have used them before...... are they accurate?
kind regards,
Edited by R33LIN
ODessA, if you're buying them together, they're $90 + postage, usually oil pressure is $34, oil temp is $34 and water temp is $31, you save $9. If you're getting the gauge holder as well, I can give a a better price too. Let me know soon, thanks.
R33LIN, it reads up to 30psi, and I still have them for sale. Where are you from?
how much for a smoked series oil temp and a smoked series afr together posted to Northgate, SA, 5085? Cheers, Andrew
Nightcrawler, oil temp $48, air/fuel ratio $61, I can get both send out to you for $110, usually $5 postage per gauge interstate, may be cheaper for same state. Let me know soon, I can get them to you by tomorrow. My number is 0402 452 455, message/ring me if you're interest, thanks.
Nightcrawler, not really, even the EL series oil temp is $35, prices are just depend on what gauge it is, and the smoke series air/fuel ratio gauge is the second most expensive gauge I have. Anyway, let me know if you change your mind, usually people get more discount when they order 3 gauges/items more, so $110 posted to you is not really bad. Anyway, let me know soon. :teehee:
ODessA, didn't know if you get my sms, but I'll keep an eye on my account and I'll update you with sms again when I get the money also when I send the item, thanks for buying. :P
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
