  • Replies 126
Seriously though, why did drift32sedan post get deleted - it didnt have anything offensive in it. As a close mate of mine I think its unfair how post like that are deleted simply because they state the truth.
Lots of you guys dont get what its all about and what the scene is and who the people in it are. They are just like you guys, enjoy driving there cars. You dont see us smirking and scoffing at track days and DECA days, but the moment drift is mentioned, you get a whole lotta people on here with the "yeah i tried its nothing special" because they cant drift properly.
Drifting is just as demanding as Track days, but the best thing about it is that to be successful at competition level, its not all about how big your wallet is.
Well said,
Some people dont know what drift is...
I agree with scotsman, love the sport don't like the scene!!
And yes i do know people in the scene possibly more people than you...
Who do you know Miss JUZ? Any Drift Australia Drivers? Any Super Drift Drivers? Two of my close mates compete in Drift Australia and they are heavily involved in the Melbourne Drift scene.
Mega Power Is one of the most upcoming drivers in Melbourne and competes in Super Drift so Its safe to say hes got 10 times more of a clue than you do.
Getting sideways out of Noble park maccas doesnt count as a drifter.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
