its not a front grill copy one from old mate down the road....umm ARE. But then again arc probably dont even know he exists. Except that looks dead straight, Richards are curved to suit that front section.
Edited by r33_racer
I don't think even the US distributor knows where it goes. I've seen similar set-ups on cars in REV magazine. They all seem to mount under the intercooler, very close to the ground.
My hope is that it mounts between the headlamps behind the grille.
Anyone else?
This is the ARC oil cooler kit for the R34 GTR. Does this mount above the intercooler? Does it relocate the filter?
that picture does not show a relocation plate, or the 3 hoses required for a relocation kit.
and more than likely it will just fit behind the intercooler, out of sight.
Just a thought.
If your gtr is stock its not a good idea to be running an oil cooler. As this obviously reduces the oils temperature, which inturn increases its viscosity making it thicker and slower moving. Resulting, in alot of stress on your oil pump that can cause it to break down & will eventually run your bottom-end dry! :laugh:
Just a thought.
... assuming he doesnt intend to use a oilstat :rofl:
Definitely using a t-stat. Tomei oil pump, mostly stock bottom. I am gonna call my ARC distributor tomorrow and see what detail he has (although probably none). I figure I'll go with the blitz (t-stat option) or get this one and tie in a t-stat. I'd like to get one that uses the space above the intercooler behind the grille (assuming that's where the ARC goes).
Any suggestion of other makes that places it there on an R34?
thanks!
thanks!
Iv always thought a simple kit like the ones on JustJap would do (though you’d have to add a oilstat)
- Mocal - a brit company making a LOT of stuff
- Theres the cast take off’s from Revo RaceGear then just add a qual cooler, sereck or what ever.
Theres a few options around, most cheaper then buying a jap name brand. That said adding a cooler / remote filter can be one of those simple things, you f*ck up and pop a motor doing. So please take cost, build quality etc all into consideration. If your not comfortable with making up lines, Earls, Speedflow Aeroquip etc, then call the enzed guy.
As for locations on a R34,
- between IC and radiator is often used spot
- in one of the front brake ducts ( drivers side) though not sure if that area vents to the wheel cavity or not [cross flow]
- low, under the radiator… but then that’s old rotary style, and seems a little risky for track use etc. Tis like having your testicals mounted below your knees “they bound to take a knock” – a bash plate or something could help.
- further underneath he car, near the gear box?
Cheers
M
that kit pictured mounts in the bottom of the main front bar opening on an R34 GTR. it mounts right at the bottom, on a little bit of an angle.
I have a pic somewhere of one I saw a few years ago in Japan. will dig it out.
Above the front diffuser?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
