Sorry, but I personally think it looks FUGLY.
Would be a whole lot nicer if the width continued right through the length of the body, but it just looks like add on bumps.
Cheers, D
I agree the that car does look a bit fugly but the wide guard DR has potential.
The Ultmate DR
Full roll cage
custom carbon fibre kit
Custom FJ24ET (ala OS GIKEN with low comp pistons), custom manifolds, intercooler etc.
R32 or 33 based front and rear suspension, maybe even 350Z/V35.
I know the above completely insane, but I would love see a hard core DR30 "silhouette style" DR30.
One that looks a bit less carton the Tomica R30
(with FJ based engine).
Dreamin
Edited by DR30RULES
https://www.sau.com.au/forums/topic/144409-widebody-dr30/#findComment-2708023
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
