I am considering getting one of those 28$ delivered turbotech boost controllers.
I have tried reading the thread but honestly!!!!!!!!!!!! 70 pages ??? i ran out of popcorn..
:huh::P
ok well i am just curious if these are as reliable as an EBC.. as I do not want to damage my engine by boost spiking....
i figure use this till i get a pfc then at the same time ill get an ebc and put it up to around 14psi.
I have:
4" hks zorst tback (front dumps) (going into std cat) :)
and cooler
air filter
these are my performance mods
only wish to raise it to say 12psi?
i had it dynod stock with catback zorst pulled 160.5@ 9 pound boost
I figure i would be running close to 10 - 10.4 psi now as thats what my gauge reads (aftermarket).
curious what a safe level to boost it to until i get my pfc ect.
STOCK ECU :-P
12psi is a fine level to run. once you start going higher you run the risk of the turbo losing the compressor wheel, and the ecu hitting rich and retard.
i use one of these controllers and i run 14psi on it and it holds fine. it does bleed off a bit at high rpm, but you have to weigh up the price vs performance. less the $50 for something that will do the job more than fine, or hundreds of dollars for something that will do the job a little better.
cool... so has anyone experienced any boost spiking with these units?
i dont want to ruin my turbo or ne thing just want some extra safe kws... as my mate has boosted his up to around 13 and the something happened with a blown oil seal in his turbo... and it runs like dog poo now... :P;)
i run my stock turbo at 14psi, but i am just wanting to see how long it lasts, and i don't drive it hard very often. its mainly just cruising to work so i don't get past about 3500rpm.
i had spiking just after i did my fmic install. i had it running off the hose from the bov. then i put a nipple on the pipe from the turbo to the cooler and it runs fine now.
Make sure you take off the std restrictor or it will spike I would prefer the turbosmart boost T as the adjustment on the turbotech is very very fine and the turbosmart boost T has clicks on it very handy to much boost put it down 4 clicks and if you want to go back up just do the 4 clicks again I have used both I would chouse the Turbosmart.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
