Hey guys just wanted to ask some advice. I park my car on a slight incline, so that the front is higher than the back of the car. Every time I start it in the morning, after a few seconds, there's a horrible screeching sound coming from the engine, then the screech stops, and the revs increase a little then settle down after about a second to the normal rev range for idle. I'm not quite sure what this was, i thought it was low power steering fluid or something so I topped that up, but now that that's ok I'm not sure, because if I drive off too soon, the moving off process causes some slight screeches too...thanks in advance :huh:
https://www.sau.com.au/forums/topic/144425-start-up-screeeeeeeech/
Sounds like a belt is a bit loose and when it sits it slides toward the back of the car and rubs up against something. Which belt is the scary part! Could be simple, A/C, Power steering or Alternator... or SCARY, Timing belt.
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :huh:
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :P
haha yeah you guessed right..I wouldn't know :huh: might wait to see what other ideas pop up then go ee him with a better picture
i'd say its just a belt slipping. and what is happeneing is that it is spinning for a second, then it heats up a bit and gets sticky and grips and gets on its merry way. very common problem amoung any type of car.
just go round and tighten all 3 belts slightly.
i hear that screaching noise every few months , i mainly notice it when we get some rain or a misty night , my opinion is it could be moisture getting to the belts? my opinion - im not a mechanic or anything , but i do notice it in those conditions . on my old car i got the same noise and sprayed some wd40 on them , would stop the noise , from happening in winter
Just a quick question (may be dumb lol) but how would i go about "tightening" the belts, i thought when they got worn out and started slipping you just had to replace them, can you extend the life of them?? Thanks heaps :(
Regards,
Sean
I'd replace them, but I'm picky :)
First you'll need to identify which belt is lose, they all have a little bit of slack... but you'll notice if one has more then the others.
Then find the tensioner/pulley that is on a sliding hole (when you loosen the bolt it can slide along that hole). Then just slide it until it's reasonably tight. It's not a big deal, but just remember to be careful and don't make it too tight as to stretch/damage the belt.
Wet some soap untill it becomes like Jelly then apply to the belt.
PRESTO......no noise.
That may stop the noise, but wouldn't it encourage more slipping?
Soap acts as a lubricant, especially when moisture is added.
If you want to be that dodgy, you'd be better off pouring coke on the belts.
The fix for you...did this last week on my Maxima.
Cheers
:sick:
Damn, that sounds like a good fix, might try it in a min :wave:
thanks for all the replies guys :spank:
When the soap dries it ends up being a dry lube.
Coke :spank: .....is only when u use Bourban......
Dodgy you say.....my mechanic recommended it.
Angry Fist.........Post up your results after you have lathered up. :sick:
The thing is you dont want to lubricate anything here. Belts arent supposed to slip.
Another cause for a slipping belt if its not just slack is it can be bottoming out in the pulley. Like i said b4 check for correct belt tension and signs of slip and replace or tighten as necessary
I recently had a loose fan belt that made the same noise until the alternator regulated output to 14V, then it would stop.
Tightened a smidge and it's good as gold. 5mm just like Deren suggested.
PS Using the soap is a good way to help identify which belt is causing the noise. Washing up liquid works ok as well. It saves replacing belts left right and centre.
Tighten it up, or as someone sujested soap as a quick fix to the annoying squeek.
I'd sujest dr y soap, just take a cake of the old "sunlight" yellow shit, and why yoru cars running put it on teh belt :) I did it when mym was winging about her commodore squeeking, and becuase i coudlnt' give two f**ks about that car i soaped it up :) when i took my alternator of for re-conditioning i didn't do it up tight enough so mine did the same, but i stayed away from teh skyline with the sunlight soap, i just tightened it up :)
Same happened to me yesterday - put your hand on the pullys of the ALt and Steering pump etc when MOTOR OFF and you will soon feel which pully is slipping from the temp, near burnt my hand on Alt pully. Sure enough belt a bit loose but not imeadiately obvious.
I loosened it right off first to check it was not the bearings though, then tiightened up.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
