Start Up Screeeeeeeech
By dingleberry · Posted
thanks very much for all the replies, huge help. to follow up with @WMDC35 so stick with the de neo loom? would some sort of plug and play ECU designed for the r34/25neo work? looking at maxxecu’s but open to suggestion -
By soviet_merlin · Posted
Ooo, sounds great! -
That is self help. Encouraging others to spend more than me, makes my spending relatively less ridiculous.
Oof, I don't think you should add it up like that! It sounds much better at $21 per issue. I don't see any problem there if you enjoy the process and the result. I really like the magazine side of it with all the little tidbits and facts. Also, if anything, these forums are all about spending unreasonable amounts of money on hobbys. I wouldn't call it a self-help group because people generally suggest to spend more -
I put another 2 layers of putty and still getting pinholes. Think i might either try the filler first then putty or just leave the little specs of guidecoat as is and get primer to fill it in. I think i misread understood what you said above when you said my glazing putty wasnt enough for the size of the area. I thought you meant 1 coat and i needed to. But i think what you meant was that I needed filler first? I also went a bit too far out the repair area as my spreader is a bit large.
