Hey guys just wanted to ask some advice. I park my car on a slight incline, so that the front is higher than the back of the car. Every time I start it in the morning, after a few seconds, there's a horrible screeching sound coming from the engine, then the screech stops, and the revs increase a little then settle down after about a second to the normal rev range for idle. I'm not quite sure what this was, i thought it was low power steering fluid or something so I topped that up, but now that that's ok I'm not sure, because if I drive off too soon, the moving off process causes some slight screeches too...thanks in advance :huh:
https://www.sau.com.au/forums/topic/144425-start-up-screeeeeeeech/
Sounds like a belt is a bit loose and when it sits it slides toward the back of the car and rubs up against something. Which belt is the scary part! Could be simple, A/C, Power steering or Alternator... or SCARY, Timing belt.
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :huh:
Get a Mechanic to check asap, or look yourself... but I'd say from what you've said you wouldn't know if the belt was too loose or too tight. So go the Mech :P
haha yeah you guessed right..I wouldn't know :huh: might wait to see what other ideas pop up then go ee him with a better picture
i'd say its just a belt slipping. and what is happeneing is that it is spinning for a second, then it heats up a bit and gets sticky and grips and gets on its merry way. very common problem amoung any type of car.
just go round and tighten all 3 belts slightly.
i hear that screaching noise every few months , i mainly notice it when we get some rain or a misty night , my opinion is it could be moisture getting to the belts? my opinion - im not a mechanic or anything , but i do notice it in those conditions . on my old car i got the same noise and sprayed some wd40 on them , would stop the noise , from happening in winter
Just a quick question (may be dumb lol) but how would i go about "tightening" the belts, i thought when they got worn out and started slipping you just had to replace them, can you extend the life of them?? Thanks heaps :(
Regards,
Sean
I'd replace them, but I'm picky :)
First you'll need to identify which belt is lose, they all have a little bit of slack... but you'll notice if one has more then the others.
Then find the tensioner/pulley that is on a sliding hole (when you loosen the bolt it can slide along that hole). Then just slide it until it's reasonably tight. It's not a big deal, but just remember to be careful and don't make it too tight as to stretch/damage the belt.
Wet some soap untill it becomes like Jelly then apply to the belt.
PRESTO......no noise.
That may stop the noise, but wouldn't it encourage more slipping?
Soap acts as a lubricant, especially when moisture is added.
If you want to be that dodgy, you'd be better off pouring coke on the belts.
The fix for you...did this last week on my Maxima.
Cheers
:sick:
Damn, that sounds like a good fix, might try it in a min :wave:
thanks for all the replies guys :spank:
When the soap dries it ends up being a dry lube.
Coke :spank: .....is only when u use Bourban......
Dodgy you say.....my mechanic recommended it.
Angry Fist.........Post up your results after you have lathered up. :sick:
The thing is you dont want to lubricate anything here. Belts arent supposed to slip.
Another cause for a slipping belt if its not just slack is it can be bottoming out in the pulley. Like i said b4 check for correct belt tension and signs of slip and replace or tighten as necessary
I recently had a loose fan belt that made the same noise until the alternator regulated output to 14V, then it would stop.
Tightened a smidge and it's good as gold. 5mm just like Deren suggested.
PS Using the soap is a good way to help identify which belt is causing the noise. Washing up liquid works ok as well. It saves replacing belts left right and centre.
Tighten it up, or as someone sujested soap as a quick fix to the annoying squeek.
I'd sujest dr y soap, just take a cake of the old "sunlight" yellow shit, and why yoru cars running put it on teh belt :) I did it when mym was winging about her commodore squeeking, and becuase i coudlnt' give two f**ks about that car i soaped it up :) when i took my alternator of for re-conditioning i didn't do it up tight enough so mine did the same, but i stayed away from teh skyline with the sunlight soap, i just tightened it up :)
Same happened to me yesterday - put your hand on the pullys of the ALt and Steering pump etc when MOTOR OFF and you will soon feel which pully is slipping from the temp, near burnt my hand on Alt pully. Sure enough belt a bit loose but not imeadiately obvious.
I loosened it right off first to check it was not the bearings though, then tiightened up.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
