Oh shit, i'm so sorry everyone! I totally forgot to put up ticket prices.
If I have 10, tickets are $146. If I don't have 10, tickets are $161. This includes transport to and from bris, and all drinks.
I understand this is going to be too much for some people. For me, this is a cheaper alternative to New Years, so I thought i'd see if others were interested as well.
And please guys, if you don't like the lineup, or anything else for that matter, and aren't intending on coming, I don't feel there is any need to say so in here. This is kind of an urgent thing, as first and second stage tickets are already gone, I need to book ASAP.
Cheers, Anna.
https://www.sau.com.au/forums/topic/144429-odyssey-nye/#findComment-2698757
Accomodation will be provided at our place if needed. We have 2 spare double beds, and 2 spare double futons, as well as a plethora of floor space.
Nice, rekon i could bags one of them? When do you need to confirm bookings and get cash?
https://www.sau.com.au/forums/topic/144429-odyssey-nye/#findComment-2708804
Sure thing michelle! It would be so good to see you again!!!
I just sent a PM about 2 minutes ago asking everyone to comfirm their status. If all 9 respond positively, I will go ahead and make the booking today!
Once I have purchased the tickets, I will let you know, and from there it will be up to YOU to find a replacement buyer if you cannot attend. Tickets will be $146.
https://www.sau.com.au/forums/topic/144429-odyssey-nye/#findComment-2709402
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
