  • Replies 41
If you can find a good condition rotor that is!
Go the 34! If your not out to be a track hack, 34 is great for daily driving. However, NO STICKERS PLEASE! :)
Punks will target your car more and it doesn't add horsepower, engine mods add power. :)
WTF? no more unconfirmed comments like these please..... :)
i cant imagine a r34 4 door would be more expensive than a two door, maybe they will be harder to find in as good nick as that black one.
its a worry.....
Ninjadust, it might be worth having a look at www.racecoursemotors.com.au they are advertising an r34gtt for less than $30k (fairly high kms though).I'm not sure how much confidence you have in odo resdings on imports, but I usually pretty much ignore them and use overall cond as more of a guide. (Some cars seem pretty rough for very low annual milage)
That is a nice black GTT. I have a soft spot for black cars cause they come up like showroom finish after you take it to the carwash. I had a yellow GTT R34 with the exact same body kit (C-West) and that made a big difference to how nice it looks. That is a genuine C-West from what I can tell and it cost me like $8k to get it supply, fitted and painted.
I say Buy iT!!! Its a great daily drive and you will get attention. Your little boy will love it too as it gives him a bit of a rush when you give it a hit. He'll be saying, "Daddy, go faster, my tummy tickles" hahah. Well, that's what my nephew said to me anyway, but uncle instead of daddy...small point of clarification there. ;)
I've seen the white GTT in the flesh at RCM. Very nice indeed and well priced. Pity it's a tiptronic though, very boring to drive. But if that's what you're after, it's a bargain. There's also a totally stock purple R33 GTR in the shop for about $38-$40k. I drove that one and she screams. Interior is excellent, paintwork is very good but may need touchup if fussy. Needs new tyres and alignment, but otherwise, there's nothing that needs to be done.
yo, if you like the car and obviously you do then well hey buy it! thats what i reckon, however the rear spolier is a bit bad you should change that. money is there to be spent as long as it wont leave you sleeping in the streets in your new r34 and eating out of dust bins then buyy the byuetch.! my 0.02
Big link, hope it works.
Nice R34 4door.
http://www.carsales.com.au/pls/carsales/!cs_results.display_vehicle?dweb_id=&vehicle_id=1185045&instant_flag=&service_id=21&total_rec=38&current_rec=21&multi_flag=0&order_by=photo_avail+%3Asort_order%2C+vehicle_id+desc&sort_type=DESC&make_id=5&model_id=73&region_id=104
  • 11 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
