Im hoping it will chirp second
Anyway the kkr 530 in basically a 480 with a front compressor the same size as a hks 3037…..Kkr 530 with nokia 1000 rrp
Manifold is g-tech 249 + 35 delivery
Dump has a v ban clamp 180rrp
This is the full setup around the 1500 mark
Funnily the kkr turbo has the same thread as a stock vl turbo gear so all my braided lines bolt straight on
199 for the china wastegate
Anyway ill put her on the silvia and see how long she stands up to 14psi and hopfully 280rwkw
https://www.sau.com.au/forums/topic/144472-cheap-rb30-power-up/
  • Replies 98
pictures aren't quite big enough, i can't make anything out :(
while you probably already know that open collector + split pulse housing is a bad idea from a gas flow perspective, it's a really super bad idea if your turbo-manifold gasket is split pulse as well. it can break off in the centre section and go through the turbine, not a good thing. make sure you trim it down (cut the divider out) if this is the case. it won't be optimal, but it'll do the job.
cheers
ok.. one thing i really do not like.. that looks to be a splitpulse T3 exhaust housing on the KKR turbo.. however your manifold isnt splitpulse.. i wouldnt reccomend running that :S its allright with splitpulse manifold with normaly exhaust housing.. but otherway around has always been a big no no in my opion and many others i know of with vast amounts of turbo experience
might loose some grunt i supose... guess the exaust gass will take the easy way out and might make it a tad laggier.. guess ill find out
or i could put a divider in there .. but lets face it that aint going to happen due to lazyiness
oh and those cases are for my lub's and makup
:laugh:
Given the work/trouble you're going to, surely a day's down time + 100 bucks (depending) to put in a divider is worth it?
Despite the opinions about these units - and my own Garrett type leanings - I'm going to be interested to see how it goes.
yeah lovely pj's you sick bastard. intercooler on the bed ehh... I dont even want to know what the "inlet" looks like now.
get cracking big boy. i need a loaner car for the next skid pay day, and you are top of my list. :D
what was the verdict on the manifold? split or not split.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
