Hey all just wondering how laggy the setup actualy is been offered t88, mani and gate for a reasonable price am contemplating it.. just would like to know how laggy it will be before i think about it
i assume nothin happens untill about 5500-6000rpm?
cheers
Warrick
Edited by rb26s13
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/
There are many types of T88.
We use the smallest one the T88-33D. The power of the Big single is hard to beat.
we are currently making 395AWKW on 22psi.
I suggest you have a rebuilt motor so you can take full advantage of that turbo.
even with say 400 awkw the lag you get over small twins, it might not be worth it.
We are going to see if we can bump to power up to 500awkw.
The power band get mover much higher into the rev range with a T88 so just remember unless you have a good motor(low lev limiter) your power band will be smaller.
The fastest circut GTR in Japan Runs a T88-33D.
I 2.8L would be good with the T88 range or massive revs.
Either way they are great turbo to use.
A mate of mine is putting a T88-38GK on a 4L V8 so it will be interesting to see how that goes.
Just one other thing people say they have lag, our car makes stock GTR power 160kw then it goes mad at about the 5k mark.
Cheers
Edited by 600hp
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2699531
it will be goin on a stock motor to start with.. am slowly building up a new motor.. but yer i just blew up the stock turbos and would prefer to only pay for turbos or a turbo once and once only..
im unsure of which spec t88 it is will have to find out tho
but yer 5000-5500rpm lag isnt that bad as rev limit would be set at around 8500-9000 to make some use out of it on the motor thats in there
oh yer if its makind half decent kw off boost seeing as its in a silvia would go allright.. come to think of it 160kw is more than wat a sr makes with stock turbo and a few small mods...
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2700590
9000rpm with a stock bottom end is not going to last very long.
I think it is widely accepted that over 350rwkw you are cheating death an rb26. The older it is the more you have to be worried about.
You will also definitely need a power fc so the car will start and run and injectors, cams and fuel pump to make any sort of efficient use of the turbo.
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2700642
"9000rpm with a stock bottom end is not going to last very long... The older it is the more you have to be worried about..."
Strategy wise...I like your idea, big arse turboed RB in an S13, but tactically... I think your heading down a path of pain.
That sort of turbo with that sort of potential going on stock combo reving to 9K doesnt sound good. To make it worth while I would have thought collecting the parts...N1 block, stroker kit (or not) or suitable crank, quality pumps etc would be the way to go, when thats done build it along with the g'box your going to need and then sell the still intact RB26.
Buy some 2860r Garretts and sell them at a respectable loss when the time comes.
Good luck rb26s13
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2701330
You could also look into TO4Z's and Garretts GT4088R , more modern wheel and housing designs at least in the 4088R . TO4R wheel pretty good too .
TO4Z very popular , can stay bellow the trashed engine end of the rev range and make more than respectable power . Used std engines in high states of tune often end up in the scrap bin .
Whats the transmission and wheel/tyre budget like ?
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2702104
Good luck rb26s13
read below.. and also... i have tendancy to "collect" not pull off and sell :D
I think he means he will put the turbo on the stock motor but not push it till the built motor goes in
i was wondering if anyone had seen that part of the post... :)
i was seriously considering a HKS T04z kit however.. my turbo's have blown at the wrong time for me as i only just got the f**king thing goin again.
eitherway it looks like i'll probaly be slide to highflow and steel wheel the stock r32 turbo's.. seeing as i just cant afford to do the single conversion at this point in time so well yer will be good to see how the highflowed stockers go..
also this way i can get the hks t04z later down the track when i want it and not loose out to much on the stock highflows if i'd even get rid of them.
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2705436
I think I'd put the money into 2530's or the Garrett marketed equivalent GT2860 . These will sell later more easily than dinosaur bush bearing hi flows and may work better than you think . 5000+ boost threshold is terrible in any street car , highly impracticle IMO . Dyno numbers are one thing but precious few drive dyno's for a living .
Sorry if I sound sarcastic but I can't see the draw to such a high state of tune when the power can be had in a more usable rev range . Big revs mean high wear and tear and bucket loads of money to make the transmission survive . I cannot see how rear wheel drive in an S13 (let alone the S13 chassis) can make use of the power you are talking about .
Still to each their own .
Cheers A .
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2705508
I had a t88-33d on my 25, was on full boost just after 5, with stock cams & head. Awesome turbo, if your getting it cheap go for it. I was making around 450rwhp on 22psi.
h.
I agree with the above statement!!
If you asked me for my opinion, I would tell you to buy the turbo kit and when the time comes to building your motor go the 3ltr route. There are a few (very fast) track cars in Japan running 3ltr bottom end with the T88-33D.
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2708146
i doubt the highflows will be all that much laggier than stock.. they will only be small highflows nothing big.. so im not fussed.. also i'd like to go 2530's but.. for the price of the highflows i am not fussed they will do the job.. if they get me 300rwkw i'll be happy, if not i'll still be happy that there are steel wheeled turbo's there not ceramic.
i will never be goin 3litre in the silvia.. i want to retain the factory bonnet and if i go 3litre.. means i have to make a hole and adapt some sort of scoop/bump to it.. i like the stock bonnet.
https://www.sau.com.au/forums/topic/144503-t88-on-rb26/#findComment-2708480
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
