Your Choice
29 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 167
everybody wants to poke fun. last time i checked, my mini did around the same 1/4 mile time as a stagea. brad's being the exception. he cheats.
oh yeah MRO, im in parky. he he. really close.
ill make the effort im just getting tired of always having to catch the throttle cause the stupid thing wont idle properly.
hmm that would have been a biatch to fix then kylie..did mitchy do all the work for ya? :)
Heath wont do you get a lift with someone that has a spare seat and then you wont have to take the mini???
hey mitchy its a good job u are coming along in a skyline as u can attract all the cop attention away from my stagea :) i removed the rear muffler tonight and only have a single 3.5' straight through muffler on it and its farkiiinnnnn stupidly loud and will sure get the wrong attention if we happen to see mr plod along the way :)
i need to buy another 3.5' muffler but not till the tune on tuesday so ill have to live with it as it is :) it sounds more like a rotary than a 6 cylinder with the cams lol
oh im excited to actually bring the stagea along this time and cruise with another 10 of them :)
so what time we meet at hillarys then???
is it old age :)
FIRST POST HAS BEEN UPDATED WITH DETAILS OF THE CRUISE SO PEOPLE DONT HAVE TO SEARCH PAGES FOR ANSWERS TO TIMES AND MEETPOINTS
TAKE CARE GUYS AND SEE YOU THERE :)
lol hope you're going to set your alarm this time Kirstie :no:
ps: yes Mitchy did all the work after we got the studs removed professionally - cause them things are a biatch to get to when the motor is still in the car!
This was gonna be a message telling you I am bringing a mate in his R33 but he burnt his clutch out last night LOL!
Anywhoo, is there any chance we can get the map (before the meet in Murdoch) in case we get there a little late?
(I have a wife and 2 daughters so this is a distinct possibility!)
i can send you the word document and you can print it out on your end if you like...
*have put the cargo barrier thingy in my boot so i wont forget to give ya that either*
do the same for me please.
i got a 21st the nite before so arising early might be a drama with a hangover and all. he he. ill do my best though
TYPICAL BRITTISH CAR OWNER - STARTS MAKING EXCUSES AT LEAST 2 DAYS OUT :)
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
