so here's my issue...
sometimes when i turn the key, nothing happens
so i try again, and nothing
eventually, it cranks as usual...
other times, it cranks with no problems at all, as soon as i turn the key
other thing to note is that all dash and everything electrical still works when this happens
anyone have any ideas?
i'm thinking electrical, maybe alternator on its way out? but i have no charging issues..
maybe a poor earth on the alternator? can someone tell me where the earth wire is on the alternator?
any other help would be appreciated..
cheers,
Warren
https://www.sau.com.au/forums/topic/144618-no-crank-when-starting/
Do you hear a little click? If your solanoid in the starter motor is weak or has a bad connection, it can sometimes half-engage. The motor in the starter won't start over as a safety precaution (so you don't grind the gear on it as it's starting to engage).
Some people get stuck like this, and have to whack the starter motor with a hammer to dislodge the solanoid. (not on Skylines, mind you.. older cars that you can get a hammer onto easily)
Might be worth getting an auto sparky to check the wiring to the starter?
thanks mate..
i don't recall hearing a click when it happens, rather just hearing nothing at all..
i don't really get out and try anything when it happens, as i usually can just try crankingit again and it cranks fine the next time
hmmm odd
might get an autoelec onto it sometime in the future (getting my car lowered monday so maybe after that)
Oh.. I just read your avatar info... it's an auto, yeah?
You might have a funny/loose wire in the auto shifter surround? There is usually a "neutral" or "park" sensor that operates much like the handbrake sensor (that turns the light on the dash on).
If that little switch is a bit dodgy, the ECU thinks you're in gear, and refuses to even start the starter motor, so that it doesn't chew itself out as it tries to launch your in-gear car.
If it plays up persistently for a few tries, wiggle the shifter a bit, and try again. If that seems to work every time, then you need to change that sensor switch.
If its the inhibitor switch on the auto a jiggle of the t-bar or trying neutral instead of park may get it to crank.
On the other hand if its a starter issue a separate starter relay fix a bad earth etc...
Edited by Godzilla32
a good way to try that is to stick it in neutral. autos will start in neutral too.
3 main things it could be if you turn it to the start position and nothing at all happens.
- Ignition switch (start position contacts dirty/burnt out)
- Auto Inhibitor switch (if its auto)
- Starter Motor itself. (Solonoid or brushes)
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
