D0P3Y is the only smart one hey,. yeah got my HR licence in my dads Mack, has an 18 spd roadranger, big arse turbo,spools up like a mutha, sounds awesome, sorry if it was a waste of a thread, just wanted to see if any one wouild pick it,
any one else got a truck licence?
cheers
Jeremy
Edited by DVS32R
https://www.sau.com.au/forums/topic/144621-got-my-licence/#findComment-2702357
hey can u post pics of the truck - exterior, interior and engine
i have always been curious to see it. My dad used to work at a cement factory as a production manager when we were in the middle east - the old mack trucks were freaking huge! Me and my bro used to always sneak up and sit in the drivers seat and just drool over all the controls - ofcourse the workers couldnt do much cos we were the sons of one of the top people in the company - ah good old memories....
pics would be mad tho :P
https://www.sau.com.au/forums/topic/144621-got-my-licence/#findComment-2702375
yeah nice, MR will be a fun test, not sure if i am going to go that far yet.
i will take some pics of the truck on monday when i go back to work. theyre heaps fun to drive, found out yesterday if you turn sharp the inside 8 wheels start to spin, maaad.
obviously not going to keep doing it cause im sure that it cant be good for the axles and diffs,
cheers
Jeremy
https://www.sau.com.au/forums/topic/144621-got-my-licence/#findComment-2702705
cheers
Jeremy
Supposedly you just got a HR licence, but you won't get an MR?
MR comes before HR... :D
Unless you're talking MC and HC... :thanks:
https://www.sau.com.au/forums/topic/144621-got-my-licence/#findComment-2704657
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
