Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
  • Replies 240
Posted Images
So whats the go?? when are the gears going to be shipped?
Made payment on monday takes 3-4 working days for money to clear then my supplier advises me on approx arrival time, ill advise soon as i hear.
Any update since money was transferred last Mon?
Good new's i recieved email from US supplier, cam gears will be leaving on the 17th Jan from the US.
Edited by r33kid
yep on there way usually take about 4-7 days, so should have them here soon.
Soon as they land ill post up here and start to despatch.
Once again thanks to all.
Is the inlet cam gear *exactly* the same as the exhaust cam gear?
If it is, does anyone want to buy a gear?
I've put my name down for a pair of gears, but after doing more researching and buying a powerfc which will control timing on the inlet side, i think i only need to adjust the exhaust side to get some extra K W 's. Is this right???
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
