Group Buy # 3 Arospeed Adjustable Cam Gears, By Popular Demand
  • Replies 240
Posted Images
Is the inlet cam gear *exactly* the same as the exhaust cam gear?
If it is, does anyone want to buy a gear?
I've put my name down for a pair of gears, but after doing more researching and buying a powerfc which will control timing on the inlet side, i think i only need to adjust the exhaust side to get some extra K W 's. Is this right???
So are the exhaust and inlet gears exactly the SAME or DIFFERENT?... Can any one pls confirm?...
I'll take a pair if anyone backs out.. PM me R33kid or anyone who decides they dont want either.
Cheers
Karl
Hi Karl,
I have sent you a PM..
BUT, if anyone else is interested.. I'll have a spare set up for sale when these gears arrive because I have decided to keep one engine for spare parts :P
You'll have a choice of Red or Blue as I ordered 2 sets of each..
Let me know if anyone is interested..
Regards,
Sherwin
good news cam gears have arrived and are in customs. should be any day now.
r33kid - are the inlet gears the same or different from the exhaust gears?
Hi there,
I'm pretty sure they're EXACTLY the SAME!
I don't see why there would be a difference..
Hi Karl,
BUT, if anyone else is interested.. I'll have a spare set up for sale when these gears arrive because I have decided to keep one engine for spare parts :)
Regards,
Sherwin
Im dead keen on a blue set if they will fit R32 GTS-t :wave::wub::)
Im dead keen on a blue set if they will fit R32 GTS-t :O;):O
I've sent you a PM..
Let me know what you think :)
UPDATE
Red cam gears in my hands will despatch ASAP
Blue cam gears still in customs, lazy bastards but hope to have by end of the week for despatch.
UPDATE
Like usual R33kid,
I'll leave trader feedback when I recieve the gears :P
If anyone has a blue exhaust cam gear for RB20 left over pls let me know. I will take one
Cheers :)
So when should red purchased gears arrive to the Melbourne buyers?
;) I could of forged my own gears by now. :P
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
