1994 Nissan Skyline R32 GTR manual 5sp
Recently full resprayed in White without wing (boot holes professionally shaved off), car looks hot, sits on 18inch deep dish wheels, 3" straight thru exhaust, HID headlights
Asking Price: $15 000 ONO
Killometer's: rebuilt 5000kms ago, bottom end knock
Complianced: Yes
Registration: 11 months rego
Crash History: No Accident History - Inspection Welcome
Other Comment's about the vehicle: Purchased this car from friend who did a rebuilt, spent 12gs on the motor. Since ownership, I did a full respray in white that costed 5gs.brought a set of 18 inch deep dishes. Fitted a Apexi Power Fc w/ hand controller, front camber kit, new blitz 850cc injectors, greddy profec B spec2 boost controller. Driven the car for about 2000kms and started hearing a bottom end knock, unsure what the problem is. Dont have the funds to continue with project. Serious buyers only.
Sydney buyers only unless your willing to come down yourself and look at it personally.
No pictures and there wont be!!
Contact detail's Sam 0423 069 456 , or PM (prefered you called if you are serious)
Edited by defect
https://www.sau.com.au/forums/topic/144640-syd-1994-r32-gtr/
Whats the catch?
Rebuilt.. Resprayed.. Power FC, Rims..
$15k is way too cheap IMO but hey if its legit then im pissed off cos i need to sell my car to get this.
White 94GTR is EXACTLY what i wanna upgrade to =(
Edited by MADGT4
Whats the catch?
howcome no pics? just blank out the numberplate?
who complied it?
reciepts for motor?
who built the motor?
what clutch has it got?
all are valid questions. pm me if you dont want anyone to see it for whatever reason.
no receipts for work, no pics because im looking for a quick sale
if your interested, call the number. possible spun bearing
not interested in interstate buyers. Sydney only!
if you want a quick sale put up some pics...generate a bit of interest....instead of putting people off with comments like "No pictures and there won't be"
it makes you sound like a real wanker and makes people suss on the car and the deal.
If i post pics, im gonna be sitting here answering PM's all day
I dont have the time to post pictures and sit here answering all the PMs
I can say 100% this is a genuine sale, you wont find another deal like this. 94 model (latest of the r32 gtrs), clean paintjob, ecu, injectors. The car owns me close to 37k. I dont care what anyone actually says because Im getting callers everyday and there are people coming to look at it so it dont bother me but thanks for your advice.
Good call
Enough chat guys, if you arent genuinly interested in purchasing this car, do not post.
If people cant control themselves and continue to post their 2 cents, warnings will follow.
Guest
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
