im only 2 months new to my skyline and havent been on a long trip with it yet , i was wondering how many kms do you guys estimate on a full tank , going at 100/110 kms - any one know roughly how much i would be expecting to get ? thanks
https://www.sau.com.au/forums/topic/144689-fuel-consumption/
hey mate i got rb25 same as you judging by your sig and i find that it uses little to none on the hwy to the coast n thats 110kms.. topped it back up to full yesterday after driving to the coast n back which is bout hour each way plus stuffin round n that while there n only took 20L which i thought was good !!
be interested to see what other people think
i usually drive from sydney to brisbane . in old car id fill up 2 full tanks and a just a quater . 1000 kms one way . smaller tank though and 4cyl ..
but i wouldnt boost her at all on the drive itd be good to get around 500
thanks for the posts
i do trips to coffs harbour all the time from syd, fairly stock r33. Used to get around 8L/100km but now my o2 sensor is on the blink i think i get around 10L/100km. So still not bad. City driving is a different story altogether, lucky to get 300km from 3/4 of a tank
Don't know my actual reading,
but I used to get 230KM to the halfway mark, around town.
Did a trip up the freeway yesterday, go home, sitting at 190km, and it's only on the 3/4 mark. So used half the fuel, for basically the same, and I generally get 12:/100 around town, so that's looking at around 6-8L/100KM on the freeway.
Damn good if you ask me (Considering if I felt like it, 6 or so seconds on full throttle in 5th gear has me seeing 170 odd KM/H if I need to overtake on a country highway.
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
