im only 2 months new to my skyline and havent been on a long trip with it yet , i was wondering how many kms do you guys estimate on a full tank , going at 100/110 kms - any one know roughly how much i would be expecting to get ? thanks
https://www.sau.com.au/forums/topic/144689-fuel-consumption/
hey mate i got rb25 same as you judging by your sig and i find that it uses little to none on the hwy to the coast n thats 110kms.. topped it back up to full yesterday after driving to the coast n back which is bout hour each way plus stuffin round n that while there n only took 20L which i thought was good !!
be interested to see what other people think
i usually drive from sydney to brisbane . in old car id fill up 2 full tanks and a just a quater . 1000 kms one way . smaller tank though and 4cyl ..
but i wouldnt boost her at all on the drive itd be good to get around 500
thanks for the posts
i do trips to coffs harbour all the time from syd, fairly stock r33. Used to get around 8L/100km but now my o2 sensor is on the blink i think i get around 10L/100km. So still not bad. City driving is a different story altogether, lucky to get 300km from 3/4 of a tank
Don't know my actual reading,
but I used to get 230KM to the halfway mark, around town.
Did a trip up the freeway yesterday, go home, sitting at 190km, and it's only on the 3/4 mark. So used half the fuel, for basically the same, and I generally get 12:/100 around town, so that's looking at around 6-8L/100KM on the freeway.
Damn good if you ask me (Considering if I felt like it, 6 or so seconds on full throttle in 5th gear has me seeing 170 odd KM/H if I need to overtake on a country highway.
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
