sandwich plate can be used for any oil sensing application...
i use one for my oil pressure gauge
go to www.justjap.com and get a "sandwich plate" for $30 or so:
http://www.justjap.com/parts_ngauges.htm (its the last one on that page)
that allows you to screw the oil pressure sender onto that
then, screw that in between your oil filter and block and wire it up!
i have attached a picture of the sandwich plate with OPS attached when i did it on my car. hope that helps!
cheers,
Warren
I have that as standard on my car for the stock gauge. Surely you can just run it from the original sender (providing its accurate). Dont all RB's have a similar sender unit for the stock gauge? Either that or remove the (possibly dodgy) original sender and fit the new sender into the original location. if need be you can splice the original gauge in with the new ones wire so both work...
Edited by Godzilla32
you can't run it from the original sender.. that's what is the problem with the stock gauge
and if you remove the original sender, then you will lose the stock gauge functionality - yes it doesn't work anyway, but it has a "low pressure" light that does work and is useful to keep going
so really going a sandwich plate is the only option to keep the standard gauge and the low pressure light, whilst also being able to run an additional gauge.
Deren, when you say "you have that as standard" do you mean the sender itself, or the sandwich plate? i wasn't aware of any cars that came out of hte factory with a sandwich plate for any of its gauges..
