R33 Gtr Air Con Doesnt Work?
JUN R33
 Share
depends what is wrong, im going throug this atm in my 32 gtr.
if gas is gone then there is obviostly a leak, could be any o ring from very easy to fix, to more difficult to o rings in the compressor. Even the evaporator inside the cabin could be leaking.
Best thing to do is get it gasses up and check that it works, make sure they put in heaps of die. This is so you know everything is in working order or not, and if it leaks the dye will shop up where it is.
If it leaks again then they will use a UV light to find the leak, then you can go from there.
Thanks for your advice...I'm basically buying the car at a reduced price because of the air con problem and I'm hoping its not going to cost me more then the $1k 'saving'...
Are there any new parts required or can any old yellow pages air con guy fix this problem?
Gas and dye is generic obviostly, if seals are gone they are pretty standard. There is a thing called reciver dryer, its like a filter for the gas, dont replace this straight away because if it leaks again, you will have to replace it again, as it should be replaced when ever gas has been lost (there for air and moisture is inside the system)
so regas should be around 100, reciver dryer is about 80 (there are different styles but in 99% sure you dont have to use genuine nissan) then rebuilding compressor i dont know i havent come to that yet, but i would imagine you should come well under $1000.
Edited by GTR1993
As you may have read im currently rebuilding my GTR at the moment ground up and one of the things i recently replaced was the receiver dryer. I found that an aftermarket nippon receiver dryer was only $25 and fitted up fine. i will most likely look at servicing/rebuilding the compressor at some stage i've been told new ones are worth around 900-1000 but a rebuild/service may only be 300
Forgot to add that it could be the TX valve. They are $50 to replace with an aftermarket item (i also did this). So just to guid you to how much these items cost. The Nissan genuine item was $146+ for the TX valve
Edited by Godzilla32
A TX valve changes the liquid to gas, this sucks the heat out of the atmosphere and gives the AirCon that cold feeling.
I would like my A/C licence but new laws prevent me from getting one.
Cheers
Sumo
  • 1 year later...
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
