FWIW I have had an Auscruise AP4400 fitted to a R33 GTR.
Works fine, factory style fit onto the steering wheel with electric actuator.
Not cheap but no room in a GTR for additional vac receiver for a cheaper vacuum style.
And I know "cruise on a GTR" but it helps with the speed camera fines as the detector is not so good on multanova cameras in WA.
https://www.sau.com.au/forums/topic/144738-cruise-control/#findComment-2730111
i had the the very same unit fitted to a falcon i owned once and the cruise control worked great , i pulled it off the car when i sold it and have it in the shed will get around to fitting into the skyline one day ...from memory if fitted to a manual u need a optional switch fitted so when you change gears it doesent over rev the motor when the clutch is pushed in
https://www.sau.com.au/forums/topic/144738-cruise-control/#findComment-2755437
  • 4 weeks later...
