Hi guys
My dads 33 Gtr has been sitting around for 12 months or more as he has been overseas, the engine is now smoking mainly on deceleration. The car doesn't really smoke when crusing, we think that the oil rings may be stuck in the piston, does this sound right? or could it be something else such as valve guide seals or the wrong oil. If it is the oil seals that are stuck is there an addative that can be used to release them?
Any ideas on what could be wrong would be much appreciated.
https://www.sau.com.au/forums/topic/144754-smoking-engine/
What color is the smoke? Black, blue, white? If you have only just started to drive it again and this hasnt been going on for awhile i would possibly give it a motor flush and oil change with something like motul oil that has high detergent content. It does sound to me like oil rings so i'd be giving it a good thorough clean internally...
Hope she comes good. Was is started periodically during the 12 months?
https://www.sau.com.au/forums/topic/144754-smoking-engine/#findComment-2703702
Hi guys
Change your PCV if you find alot of oil in your throttle body.
https://www.sau.com.au/forums/topic/144754-smoking-engine/#findComment-2705411
Just give it some time and see if it comes good. If it's still happening after a week of normal driving, you should look further into it. Also, if it's blue smoke, then it's burning oil, if it's black smoke then it's running rich (maybe a cooler pipe leak, or afm problem etc.). You can do a compression test to rule out any serious engine problems (ie. rings)
If you have to leave a car without driving it, you should start and run it for 10 minutes once every couple of weeks for future reference.
https://www.sau.com.au/forums/topic/144754-smoking-engine/#findComment-2709075
Worn/brittle valve stem seals will cause the problem you have described.
Changing the oil can rectify the issue however an old trick to softern up the seals is to put a cap of brake fluid in with the oil.
Brake fluid softerns rubber and can rectify the problem. If they are too bad then nothing short of replacing them will help you, however try the cheap option first and see how you go.
People will probably jump up and down about putting brake fluid into oil but if anyone actually knows an old school mechanic ask em about it and see what they say. Works wonders for mild seal problems.
Brad
https://www.sau.com.au/forums/topic/144754-smoking-engine/#findComment-2715464
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
