does anyone know how to remove the rear seats?
Remove the 2 bolts at the front of the bottom section of the seat and it will come out .. revealing the 2 bolts at the bottom of the back section .. take these bolts out them pull forward a little at the bottom and force the seat up (sometimes can be a little difficult), the whole process should take 10 minutes.
As for the factory immoboliser ... doesn't have 1 standard to my knowledge
you will need aftermarket for the 3 point insurance requirements
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704158
If you need a immobilier try one of these......they stop anyone
But anyway,
Na the stock one isnt complient for what you need as it isnt 3 point and isnt all black wiring. i highly recommend getting a aftermarket one like a autowatch
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704211
Garry is right, they dont have one at all...
Mongoose also make a 3 point immobiliser with black wiring. M80 series.
The M80 would be my first choice for value...
I persoanlly run the M60S as it offeres battery backup and auto window up and is compatible with all turbo timers, which is perfect for turbo's.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2707997
M80 is a triple immobiliser, whereas the M60 is only a dual immobiliser, so the M80 would be the immobiliser of choice if your insurance company requires a triple (or 3 point) immobiliser system. The M80 series offers the features of the M60, plus more.
The M80 is compatible with Shannons Insurance requirements due to the triple protection of the immobiliser.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2708123
I would have to agree. The m80 is a good reliable immobiliser/alarm. go to autobarn at Slacks Ck. Not only do they know there shit, they also know skylines. i talked to one of the install dudes and he was able to say what i needed, what i didnt need, etc. Would recommend both the m80 for both insurance and piece of mind and Autobarn at Slacks Ck
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718234
whats the m80 worth and how much to fit?? anyone know?
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718526
Hi Guys,
M80 is the way to go! It has the three point immobliser, If you twist my arm I might be albe to through in a window lift module.
We have other alarms to but from my expeince mongoose are the best, If you want to be in contact with your car all the time, they even offer the SMS module.
If you have any Questions feel free to give us a call -07 54 9333 66
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718920
Well Matt the M60S set me back about $280 and it was a DIY job for an me, but then again im a qualified auto-elec... :pirate:
The reason I suggested the M60 in the first place was price... The M80 is superior hence why the model number is higher, but most insurance companies only require you to have 2 points protected and in this case money is Matt's issue so the M60 would be his best bet....
Seriouslly hit up Chris Rogers for a installed price as he will be your best bet being a club sponcer...
Better yet you can talk directlly to Sam and Chris this Sunday at the SCC... :kiss:
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2720324
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
    • Turm it all the way over and send a photo to Morgs?
