does anyone know how to remove the rear seats?
Remove the 2 bolts at the front of the bottom section of the seat and it will come out .. revealing the 2 bolts at the bottom of the back section .. take these bolts out them pull forward a little at the bottom and force the seat up (sometimes can be a little difficult), the whole process should take 10 minutes.
As for the factory immoboliser ... doesn't have 1 standard to my knowledge
you will need aftermarket for the 3 point insurance requirements
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704158
If you need a immobilier try one of these......they stop anyone
But anyway,
Na the stock one isnt complient for what you need as it isnt 3 point and isnt all black wiring. i highly recommend getting a aftermarket one like a autowatch
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2704211
Garry is right, they dont have one at all...
Mongoose also make a 3 point immobiliser with black wiring. M80 series.
The M80 would be my first choice for value...
I persoanlly run the M60S as it offeres battery backup and auto window up and is compatible with all turbo timers, which is perfect for turbo's.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2707997
M80 is a triple immobiliser, whereas the M60 is only a dual immobiliser, so the M80 would be the immobiliser of choice if your insurance company requires a triple (or 3 point) immobiliser system. The M80 series offers the features of the M60, plus more.
The M80 is compatible with Shannons Insurance requirements due to the triple protection of the immobiliser.
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2708123
I would have to agree. The m80 is a good reliable immobiliser/alarm. go to autobarn at Slacks Ck. Not only do they know there shit, they also know skylines. i talked to one of the install dudes and he was able to say what i needed, what i didnt need, etc. Would recommend both the m80 for both insurance and piece of mind and Autobarn at Slacks Ck
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718234
whats the m80 worth and how much to fit?? anyone know?
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718526
Hi Guys,
M80 is the way to go! It has the three point immobliser, If you twist my arm I might be albe to through in a window lift module.
We have other alarms to but from my expeince mongoose are the best, If you want to be in contact with your car all the time, they even offer the SMS module.
If you have any Questions feel free to give us a call -07 54 9333 66
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2718920
Well Matt the M60S set me back about $280 and it was a DIY job for an me, but then again im a qualified auto-elec... :pirate:
The reason I suggested the M60 in the first place was price... The M80 is superior hence why the model number is higher, but most insurance companies only require you to have 2 points protected and in this case money is Matt's issue so the M60 would be his best bet....
Seriouslly hit up Chris Rogers for a installed price as he will be your best bet being a club sponcer...
Better yet you can talk directlly to Sam and Chris this Sunday at the SCC... :kiss:
https://www.sau.com.au/forums/topic/144801-imobiliser/#findComment-2720324
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
