Ok guys, i have posted a few questions in regards to this before but need some more advice, there is a very limited knowledge of this stuff in the NT.
Firstly Car Mods
Rebuilt Motor (In Progress) RB25DET
Arias Forged Pistons
Eagle Rods
Cometic Metal Head Gasket
Tomei 256 Poncams
Tomei Cam Gear
Greddy Inlet Plenum
Garrett GT30R Turbo
Bosch 040 Fuel Pump
Nismo 555cc Injectors
Nismo Adjustable Fuel Reg
Apexi Power FC
Now we are looking for 300+rwkw
The car currently has the stock ECU etc.
(1) Will it be safe to bolt everything in once the motor goes back in, like injectors, fuel pump, power fc etc & run it around on the base map on the power FC to run in the motor for the first 1000km. The reason i ask is i have spoken to two local import mechanics up here, one said bolt on the new turbo & run in the motor on the stock computer, the other said the stock computer will shit itself with the cams.
(2) How strong is the R33 GTS-t running gear, ie gearbox, tailshaft, diff, will it handle 300+rwkw.
(3) I have seen alot of skylines with this power running multiple fuel pumps & surge tanks etc, but i have been told the 040 will be fine, is that correct.
(4) Anyone know if i have overlooked something.
with regards to running it it, it should be fine for only 1000km untuned.... you only have to bed the rings in etc but your cold start and running will probably be shyte. Should just run it in on the dyno
Will the Bosch 040 be sufficent for 300 to 320rwkw, i kind of want to do everything at once and never touch the biatch again lol :mellow:
from my experiance this method gives the best result.
100 kays of light duty reving. (traffic but not much ideling)
drop oil. and filter
500 kays of "normal driving" on low boost with shit oil.
drop oil and filter
next 500 kays of normal driving with a resonable oil of the same viscosity as what you want to run. on moderate boost. say 1 bar.
so after 1000 kays its readdy to rev and be given a hard time. dont drop the oil for 2000 kays.
after that its gonna be bedded in nicly. and not use oil or blow smoke or have heaps of blowby (depends what clearances your running)
at no time should you limmit revs to a pathetic 4k. if you do that you run the risk of scratching the bores one you rev it up.
what happens is as the rings bed in a very small lip is formed at the top and bottom of where they run.
and as you rev it the rods stretch a tiny amount. efectivly making the pistons travel further up and down.
if its only used to 4k for 1000kms and then give it a bootfull the rings will get dammaged.
so after the first 100 kms slowly bring the revs up to your max revs over a period of around 150kms. once yove eased it in to that you need to just drive it normaly and give it some moderatly loaded revving. like back to second to overtake etc etc.
for a referance our race civic motor we put it together and installed it. started it up,bled the coolant and went straight to the dyno.
after 10 mins it was hitting 9 grand without issue. doesnt use oil,no blowby and doesnt turn the oil black in 1 race lol
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
