Hey everyone, my r33 gtst has been having a healthy appetite for rear left wheel bearings and im wondering if anybody knows the correct torque setting for the axle nut. My bearings keep coming loose for some reason. My last resort is to get a new drive hub and try that, as i think the one on my car must be worn. any help would be much appreciated.
Bill
https://www.sau.com.au/forums/topic/144821-wheel-bearing-problems/
You shouldnt need a new hub you can normally just knock out the old cone bearings. Check for pitting and damge to the rollers. Im not sure of the torque setting but you can do it by feel. First do it up over tight to bed it in then back it off and re-nip it up so it firm but not over tight. Best to get a trained mechanic to do this as you dont want it coming off while you driving!
Bill
why are they coming loose?
do you have a split pin on the nut?
I have just done mine and had no probs
Im doin the nut up bloody tight with a good extension bar, and using the lock cover and split pin, but the bearing seems to come out of preload and only run on the outside roller, rooting the bearing in weeks. im a fitter by trade, so i understand what im doing, but there seems to be a large difference in size between the brg and the shaft, which wouldnt normally close up by preload. so i figured i might try a new hub and see if that fixes my problem.
    • Jump into the wasteland. Plenty of random posting/chatting going on in there.
    • I did not go to GTR Festival. It's quite a long drive and the car wasn't dialed in yet. I also wanted to see how the racing portion went before going. From what I can tell the classes were not heads up, index, or bracket - just whoever has the quickest ET wins. Never heard of that sort of thing before and maybe some people like it but it's not my cup of tea. I don't suspect I'll go if that is how the racing is done. I did get the car out three times and had issues each time. Some were my error - haven't raced the car in over two years - and others were parts. Had trouble getting the clutch to slip correctly and remembering how it was set up in the Haltech. Broke some drivetrain parts as well that couldn't be fixed in a couple days to get back out. Season definitely didn't end the way I wanted but at least the bearings are still fine! Not a fleck of material in the filter. Really hoping next year is the year I can actually test this car properly.
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • Yeah go with that one
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
