HKS Super Drager cat back system
Original HKS drager for a R33GTST or GTR as they share the same part number from the HKS catalogue.
In good condition, purchased second hand from SAU forums but never installed on my car. Unit has some scratches underneath main muffler.
$ 450.00
Trust Blow Off Valve Type-R
In good condition, purchased from SAU forums, ran it in my car while I was running high boost pressures (15psi+).
$ 200.00 SOLD
Defi BF Gauges and unique Border R33 GTST/GTR Shroud
In near new condition Defi BF Turbo, Water Temp and Exhaust Temp 60mm Gauges. Used for no more than 2000km. Includes individual gauge holders but does not include loom or sensors and the control unit as they are still installed on my car. These can be ordered as spare parts through any Defi dealer.
Very rare gauge cluster is made by a Japanese company "Border" basically brand new. This is for all model R33GTS/GTR, it looks part of the dash as it sits on the passenger side pointing towards the driver. Very Cool!
$ 450.00 Gauges are no longer for sale! Cluster is still available $100 SOLD
Located in Melbourne.
Please contact me via PM.
Edited by ChrisR33GTS-T
https://www.sau.com.au/forums/topic/144853-r33gtstgtr-hks-super-drager/
waht does the bov sound like...a whoosh or a flutter?
The BOV really only operates at high boost pressures even on the softest setting, so normally when you change gear early you'll get a bit of a flutter or a full woosh once the turbo hits full boost.
did the previous owner say if the exhaust was loud or quiet?
I heard the exhaust on the prev owners car before I baught it and it had a nice gurgling rumble. Even tho its basically a 4inch exhaust it has three mufflers so its never going to be loud.
thanks for the feedback Moonus... HKS of course don't make these exhaust systems anymore so they are becoming a sort after item.. It took me ages to find this one and that was over 12 months ago!!
i have HKS super dragger on mine with BAMBTL's dump and high flow cat and it sounds very nice at idle it's reasonabley quite but as you really start to open it up it comes to life (While still not being to loud) i have had a heap of people comment on the how good a note it gives off too.
oh yea it flows well too :mad:
Just letting the VIC guys know I have a few interstate buyers who are keen but VIC guys have first preference due to the inconvenience of shipping the exhaust interstate. I'll give it till 03/12 (End of Day) then i'll ship it interstate.
Regards
Chris.
Does the BOV have the strong or standard spring?
Also does it need an adaptor to fit to a standard pipe? If so does it come with it?
Edited by DivHunter
BOV comes with the standard spring. When I baught it i thought it has the stronger spring so i purchased the softer spring from nengun but found that i already had the softer version! This bov is capable of holding 3 bar (with the stronger spring i assume) and is commonly used to replace the two standard GTR bov's, so its meant for cars making big power. If you use it on a stock turbo you will just get a whole lot of flutter.
This BOV does not come with any adaptors for any cars except for GTR. As per www.trust-power.com
Updated pics with the gauge cluster. Also I'll seperate the cluster as i'm having second thoughts about selling the gauges.
$ 150.00 for the cluster (in near new condition)
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
