  • Replies 76
I've tried it..
No difference to BP98.
Wasn't able to dial in 1degree more ign other wise it would knock (same as bp98) and also got the same kays out of a tank.
I got mine from Findon as they were 'supposed' to have Optimax Extreme 100ron (renamed to V-power racing) available from ~29th of Oct.
They haven't BUT the bloke said they are definitely getting it.
http://www.coles-express.com.au/fuel.asp#1
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2704934
I've tried it..
I guess thats pretty definitive isn't it?
Any chance different cars would have different results?
lol I posted the same question in the skyline section earlier tonight ;)
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2705157
lol I posted the same question in the skyline section earlier tonight :ninja:
Not really. :D
I didn't check afr's and apart from the seat of the pants it didn't feel any different. A dyno may tell a different story.
Different cars.. Possibly one that is making a heap more power than mine, mines not making a great deal peak just a big fat mid.
On the note of fuels.. I went to have a play with the Extreme 98 10% Eth again tonight but noticed it had been bumped up to 12c more than their regular ULP.
Not sure if they either forgot to adjust the price or they have increased its margin over regular ULP. I will keep an eye on it over the next couple of days and see if the price drops down or not. So.... I dropped BP98 in. :)
Refuse to pay 12c more for a 10% eth 98ron fuel.
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2705397
According to the website, it's a different formula with some gains in performance.
The creators of Shell Optimax, Australia's first premium performance fuel, are proud to announce the introduction of their new performance fuel. New Shell V-Power with Friction Modification Technology is designed to give you better responsiveness and improved performance in comparison with Shell Optimax, the fuel that it replaces.
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2706170
so is this gunna just suck through my system like BP ultimate or will i get improved performance (gimak gimak)
i noticed in my old skyline R31 RB30de when i went from just ultimate to premium i got heaps more KM's out of it but when i went from premium in the 33 to BP ultimate it didnt last as long and there was no noticable performance
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2707221
im not sure on L/Km but i fill up each wednesday and if i dont go cruising by the time i fill up again on wednesday i sumtimes think ill struggle to make it to wednesday but filling up usually means about 50-55Lts so if my tank really does hold 65Lt then theres allways about 10Lt left in it
**EDIT**
u must drive like my grandma :S 12l/100 = 541KM/65lt tank
Edited by Madaz
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2707551
I used to get 10.5L/100km in the R32. Stock as a rock with only a pod filter on PULP (not even 98ron).
Will be interesting to see if there's any noticeable difference. I keep a very detailed fuel consumption log at home so i'll report the results here.
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2707563
**EDIT**
Quite the opposite actually. If earnt more money I'd chew through rear tyres like a dog does a chop, so I do try to restrain myself. I usually boot it whenever I get the chance though :). It;s just really important to have a good O2 sensor. I was getting 15's before hand.
You should calculate it out mate it's not that hard, & see if you got bad or good economy. Pleanty of guys are getting economy better than me, they MUST drive like grandma's :happy: or on highways a lot.
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2707626
That's where a pen & paper is your friend. Write kms & litres & figure it out later :happy:
My best ever economy was 10, but that was before the O2 sensor. I did a combine city country drive on a tank a few weeks back & got 10.7, I reckon a full country drive would be more like 9.5 now.
Edited by JazzaR33
https://www.sau.com.au/forums/topic/144857-shell-v-power/#findComment-2707758
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
