The title probably says it all...
In short, I dont believe I have anything unusual with my air conditioning setup...(ie. no problems etc.)
Its just that with summer coming and with it a lot of hot weather I will therefore be doing a lot of driving with air conditioning on.
And with air conditioning on the stagea takes more revs to get it moving and generally feels very "weighed down" as a result. I think revs also build slower... ;)
I'm sure we're all familiar with the effect of having air-con on. Just wondering if there is anything that can be improved on, obviously with the air-con still working ;)
Cheers,
Steve. :)
Wind your windows down instead lol
haha yeah there's always that. If I'm on my own I will avoid a/c until its really unbearable (windows down, sunroof open) but the wife always insists on turning it on (dont blame her really). ;)
Just wondering if everyone just puts up with having a significantly slower car in summer/hot weather or if there's some mod(s) that can be done to improve things...
nope, slow enough as it is in the heat. ive stopped using my a/c for bout 2 yrs now. i make my missus deal with it. i just drive faster to get more airflow into the car with windows down. i think having a/c on in unbearable heat could make it worst for engine - overheat etc etc.
If your wife is in the car... you probably wouldnt be doing any crazy powerful manouvres anyway one would think?? I know my fiance gets up me whenver the damn auto kicks back a gear!
hmmm yes all too familiar with this...
put it this way - I get away with it...sometimes. She gets annoyed if I take off quick etc. but she gets over it ;)
Its all good ;)
Cheers,
Steve. :)
Actually Steve there is.....
1. start the car earlier and switch the aircon to lowest fan setting but coolest temp. By the time that you drive off the interior may already have dropped a few degrees, (I am assuming that the car isn't too hot to start with.
2. Make sure the venting is set to interior only, or you are trying to cool the world down not just your car!
3. When you take off try to avoid setting the fan higher, as this will take the cold out of the condenser quicker and the air con will kick in more.
4. If the car is really hot, drive a while with the windows down to get rid of the hottest air.
5. PARK IN THE SHADE.
6. Move to Tasmania. :)
You probably know all the above, but some ppl don't.
having the windows down creates more drag stagea already has the aerodynamics of a brick no need to make it worse :D
ska doesnt notice as he has a manual he compensates for lack of power with delay in changing gears autos dont do this too well
"It could be the compressor is starting to seize up or the belt is too tight.. " says Mitchy :)
I had my air con on all day today and didn't feel any power change to the car :D And we went up some pretty good hills too..
u can buy some sort of switch setup where it cuts the aircon off when u press more than a certain amount of throttle from what ive read, unsure if its only possible with aftermarket ecus or not. try searching jaycar website as they have heaps of this electronic gismo sort of stuff.
yeah i agree with kylie i definately had no problems hanging in there right on kylies ass all day up and down some big hills with lots of twisty corners
my aircon sat on 18 degrees all day fan was on full and no issues
yeah sometimes it seems ok and sometimes it doesn't. I think a lot of it is to do with how hot the air is outside (and inside - making it work harder). Hotter air is less dense so the car doesn't perform as well as if it was cool air.
Also I was reading other aircon related stuff on this forum and I got the impression that there is a 2nd fan (in front of the radiator, not the crank one) that will turn on/off as needed when the engine gets too hot?? Wondering if its something like this - some extra fan sapping more power from the engine?? i really dunno...
Not sure how aircon works exactly but maybe there is a problem with cooling efficiency on really hot days? The temperature guage never moves once its up to temp so it doesn't seem too bad...
I should stress that the air conditioning DOES work well and has no problems cooling the car down, so I dont think there are problems with the compressor pulley or anything (wouldn't this affect driving with aircon off as well?? - since i think the aircon belt spins all the time regardless of whether aircon is on or off...correct me if i'm wrong).
And I have no problems with performance with air-con turned off. its only when air-con is on it just seems to really bog down and takes a while to build revs up when taking off from stand-still (taking off normally that is, I dont generally like to push the car very hard when its hot - its not good for it).
Thanks for the replies - on the one hand it sounds like many people just live with a loss in performance with a/c on and on the other hand it sounds like there may be some problem there...
I'll take more notice over the next couple of weeks and see if I can identify if it appears to be only when its under load (ie. a/c on and 30+ degrees outside, hot inside). :domokun:
Steve,
Yes the aircon belt does spin all the time, but the next time you have the bonnet up and the engine running, have a close look at the front of the air con compressor and you will see that there is a clutch in the front that means the compressor is only turning when the air con is on. If the compressor is on its way out, the power required to turn it wil slowly become higher and higher. This can be caused by the belt being too tight, but in my experience this usually causes the clutch to let go rather than the compressor. Have a good look at the body of the compressor because they (usually) only run a bush type bearing in the rear of the case and if this has been knocked about it will lead to a slight binding that MAY cause the symptoms you are describing.
Just my 2 cents worth...
having the windows down creates more drag stagea already has the aerodynamics of a brick no need to make it worse :teehee:
Does anyone know the Drag Factor of a Stagea. I think it is called the CD Factor.?
When I bought the RMR30, in 83, it had the lowest drag factor of all the vehicles I was considering.
"Cd" is correct, it stands for Co-efficient of Drag. I'm guessing the Stagea would have a CD of 0.38 or something ridiculous like that.
Steve,
Thanks - I'll check it out - or rather get someone more knowledgeable to check it out sometime :P
Also I noticed the ~30cm fan that sits in front of the radiator was ON today - even with the a/c off. I presume this fan is for extra cooling if the car is running too hot? It was 38degrees today so that would make sense. I also presume that this is normal operation...my temp guage was no different to normal so I hope I have no cause for concern. I did a coolant flush only a month ago.
:wave:
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
