You cut the sensor out of the std rb25 AFM and you put the sensor in to a 3in pipe because the std one is 2.5in so this means that less air will go past the sensor,has anyone done this before.
Similar to what Autospeed did except they used a seperate bypass pipe then the digital fuel adjuster to get the A/F mixtures correct.
In theory it should work the same way, just don't damage the AFM hotwires!
umm... no it doesnt
have you looked at an AFM before?
You'll see that changing the diameter wont affect it at all as the AFM wire is in the middle of the AFM itself.
The amount of air going isnt going to change
I think it would, wouldn’t the wire measure the air and then calculate that by 2.5'' pipe
so if the pipe was 3'' the air would measure the same but there would be more air in the 3'' pipe then the 2.5'' pipe.??
I'm just guessing..
area of a 2.5" pipe = 31.6cm2
area of a 3" pipe = 45.5cm2
the bigger pipe will flow more air, but since the sensor only reads what goes though the little hole it sits in, then calculates how much air that is for the designated size of the pipe, when you put it into a bigger pipe it throws the calculations out and you end up with leaner mixtures.
as has been said, the AFM wire will indeed sense less amount of air, but all this will do will make the car run leaner as it will add less fuel. without tuning it would be useless. and given you'd have to tune, it makes sense to go z32 if you are going the whole hogg
btw.. nissan AFMs use a hot wire with variable resistances, right?
but since you generally have to run some form of either piggyback or full ecu to run a z32, i don't think that leaning out would be an issue since you have to get it tuned for the afm either way.
personally i'd just get an ecu that uses a map sensor.
just know about this a while ago....
found a webpage that did this...and in the same time...upgraded his injectors...
so i think there wouldnt be any problem if u cut off the AFM and fit it in a bigger pipe and in the same time fit in a bigger injectors....and tune it back to optimal settings....
i just dont see a problem with this MOD...
plus...u can save some cash....for budget drifters....
Edited by r32gt_rb20
Bah, pack of gurls! =)
There’s a risk, but in reality if you seal the sensor to the pipe well ( careful not to use any noxious adhesives that will eat the PCB) and tune it properly, ( piggy back, FC) it would be well impressive to get it working.
Perfect for the budget conscious.
That said, for $300 there’s no way i would risk my motor :D
M
    • Pay diff/trans workshop to do this.   Nope. Z32 turbo ran R230 with 6 bolt GTR style axles. All other Z32 were R200. Basically same same as other R32 stuff. All were a viscous waste of space.
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
