i drag race with a eg civic hatchback with a b18c typ-r engine..., 1st run, i won 1 car, second run, im beaten 1 car and also the third run....i observed when my first run, i can feel the pull of the car, but it lost in the second run and third run...my boost reaches 1.7 i think
i have
apexi SAFC and AVCR
twin apexi power intake
twin turbos (i still don't know the numbers)
twin HKS BOV
blitz catback exhaust
ecu(i don't know) nissan is written on it...
i want to check all the stuff what my skyline have... can somebody help me check everything??? and is this normal beaten my typr's????? there civic used to run on 12.6 sec to 13 flat....
Edited by andy95'R33GTR
https://www.sau.com.au/forums/topic/144893-gtr-vs-honda-type-r/
dude, do you know how to drive your car?? i ran against a civic type R with a K20A engine when my car was stock (exept for the 3 inch exaust). and i smoked him about 2.5 cars. do you launch your car good??. maybe its the clutch that is breaking up. get a good clutch, and try it again, the GTR benefits from a near redline launch. and be ready to pul the second gear in no time.
everyone restrain yourselves....
now, there are two ways of looking at this. either the civic is unusually fast, or your GTR is unusually slow. or perhaps it's both.
take your car to a mechanic, get them to check it over, and do a dyno run to see how everything is performing. that will give you a good idea what to do next.
Sounds about right Andy.
Stock GTR33's do qtr mile in what 13.5 or thereabouts(with a really good driver/launch off the line).
Your car sounds stockish with just bolt on mods running stock ecu and stock turbos unless i read it wrong.
So with your current mods, pod/zorst, ebc, s-afc. you should be doing 12.5 to 13flat qtr mile with a good launch (MY GUESS).
So if you said that EG does 12.6-13flat down the qtr-mile i'm not surprised you lost.
EG Hatch with B18c (Dc2R engines) do around high 13's to 14 flat qtr mile (dunno about mods but there is a yellow eg running those times at wsid)
EG Hatch with JDM K20A (with stripped interior and bolt on mods) did a best of 12.3 qtr mile with drag tyres, plates: EGK-20A (blue one) engine has now been transplanted to a integra though.
my 2cent. (i could be totally wrong but thats my opinion)
A good driver with a good launch will do a 12.9 in an R33 GTR.
edit: Best motoring vid from late 90's.. This guy does a 12.7 in his stock 33 gtr V-Spec
http://www.youtube.com/watch?v=aRXAMk8Hx44
Without knowing the full specs of each car, this thread is totally pointless.
There are far too many variables to take into account. And really, what does it matter?
inline with forum policy... this "vs" thread is also going to be locked.
If you wish it to be re-opened, send me a PM.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
