the cat is a 'factory blockage'.
I think I've said before that a hiflow cat is actually an oxymoron.
No cat has a Hiflow, they are ALL crap flow compared to a peice of pipe.
R31 Chick,
I'm always good for a laugh even if my car isn't.
  • Replies 103
When I come in on monday and we fit the front+dump pipe and then dyno it we should look at the original dyno graph with its boost and a/f ratio and see how rich it was running. BTW: steve I got the hurricane filter from works auto as well and thats on, so that should help the AFM read better as you said.
I found out I'm not to blame for being an idiot self tuner.
The problem (knock/ping) seems to be a single piston issue. We suspect a blocked injector or two. The afr's are super rich as I have previously dialed in more fuel to cushion any potential damage.
The result was a ping at about 4700rpm that prevented us reving it any higher.power: 230 rwhp - afr : high 9 with very little timing advance
