Results will vary wildly depending on what specs you build it to. 100rwkw @ base, poverty, untuned with wrong ecu, low compression spec.
I have a twincam head for sale by the way....
Thanks guys,
I've found out that it would cost the same if not more to build a RB30DE instead of just putting the turbo (RB25DET) engine in.
What was suggested was to bore out the current block to 3L, saving a lot of hassle of getting the whole 3L engine in and connected to everything.
  • 4 weeks later...
Originally posted by NS2500
Thanks guys,
I seriously doubt that you can bore a RB25 out to 3 litres.
i am planning on building an RB30DE, with forged pistons, etc. etc.
planning on about $7000 for the complete rebuild...do it properly the first time i say. i have an R31, so an atmo belongs in the engine bay, when it comes time to get an R32 gts-t, i can just swap engines over and put a HKS 3037 turbo kit on the side. :P
cheers
Linton
$7000 seems pretty expensive, I've got a couple of quotes and I was looking at $4000 - $4500. The quote for $4500 included being bored out to 3.2 litre, and new pistons (they weren't forged though).
Look around, you could get a turbo fitted as well for $7000
yeh, i probably could turbo it....but then im in a different league, i have to compete with other turbos, with bigger or multiple turbos.
i want a TOUGH atmo, not a mild one, a bulletproof, fully worked RB30DE, so when i drive away from some turboed cars, i can say its not turbo and thats how i wanted it.
$7000 is including the other things, like gearbox, tailshaft and diff rebuilds aswell as brakes.
would beefed up R31 brakes do the job?? or would i have to get the import struts and put R32 GTR brakes on???
cheers
Linton
  • 4 weeks later...
RB series engines though not quite as long in their stroke as L series engiens were good for torque. Which is why they take well to turbo set-ups. Twin cam versions of the same engines had better breathing abilities which enables greater high end performance. This can be substituted by proper head work to allow greater flow with optimised back pressure. I've built a few RB's and L's and proper head work coupled with a good quality engine management can yield +250kW figures N/A while still using stock bottom end components. Be carefull who & what you throw money at cause somethimes they're lost causes.
What did you have to do, to get +250kw? I'm going to do the conversion, as soon as I get the funds together, but from what I've researched, 180kw seems to be the most I can expect
  • 4 weeks later...
reliability is a completely different thing. That depends on how you drive it, and i'm not talking just revs. I'm talking lauches, changes, loading, heat (oil & water), maintainance, everything. Compression ratio will also depend on what fuel your going to use. Its near impossible to go past 12:1 without using very high octane fuel. How you intending on changing compression ratio? What ever it is make sure the valves have clearance to the pistons. Would suggest staying around 10 or 11:1 for 200kW.
If done correctly, you can easily maintain excellent reliability and good drivability.
 Share
    • so finally had an event i was home for that didn't get rained off or otherwise cancelled to be able to actually drive the car, unfortunately was roll racing which isnt my favourite thing ever but had an awesome night with friends and testing the car out. obviously a huge difference in driving experience with the samsonas although still without flat foot upshifts the ratios are so much nicer and actually has boost into the next gear which was not something i always experienced with the stock gearbox. but of course absolutely loving the sound of the sidepipe and for its downfalls of ruining the car in ever other way it does sound awesome at the track.   had some weird issues where it would misfire in 2nd but fine in every other gear and at the end of the night at the end of the run would have no throttle until it decided it wanted to work, so will be looking into that before a proper track night coming up in just over a week to really see the changes in the car. Messenger_creation_C9B7F84E-0820-444B-A53D-9AD40F7DDC5B.mp4     received_870009858147161.mp4   Messenger_creation_046B1D12-ABA0-4B01-B78F-262559E64ADC.mp4  by the end of the night found that if i was nice and gentle on the throttle in 2nd it wouldnt misfire so was only fully throttle and loaded up in 2nd it would occur
    • I think I will try out Frenchy’s power steering kit. Looks like a better solution.
    • Useless lot aren't they? Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol. FFS.
    • Similar experience with Ross pulley. Can't recommend.
    • Hey guys I’m putting my 180sx wiring loom back into my car and I’ve run the interior harness out I’ve noticed that on the passengers a pillar there seems to be a section of holes where zip ties would go as if to run a thin 4 wire harness to the roof I’ve searched through all of my stuff to try and find this harness but I can’t seem to find anything. I’m just wondering what the passengers side a pillar( on the windscreen) harness/wiring is actually for as I have already wired up my interior lights cheers
