a cheap option is the 'plus 50' narva range. I've used them in several cars in the past,and in my S2 when it still had halogen globes in it,before I bought a set of factory HIDs.
at ~$30 a pair,you can't go wrong.
Justin...
Edited by fergo308
  • Replies 60
Posted Images
well i upgraded my H4s light into low xenon high halogetn HID conversion kit. Overall im really happy with the result from the conversion. im using 600k co;or s[ectru, pf cpurse anythin higher is actually deemed illegal. so....
OK, I'm confused, aren't the best fog lights supposed to be yellow? I have 5 cars and 3 of them have yellow fog lights (the Stagea being one of them). Personally I find that they are much better in the fog than the other 2 cars that have white fog lights.
:mad: cheers :)
Boy am I glad I live in WA..... don't remember when I last drove in fog!! ;)
Actually any aftermarket HID conversion is illegal unless factory optioned lights are used (AKA, installing S2 XENONs in a car without XENONs). This is at the reflection pattern of a halogen light is different to HID systems.
yep i know that but i havent seen an s1 hid headlight before though so i thought wat the heck whack it on and it came out good cant complain of course you have to sdhust the head light assembly assy down a bit in order not to shine onto oncoming traffic.
  • 5 months later...
Having been the owner of both an S1 front and S2 front, I am glad to produce the following information.
S2
High beams are HB3 60W
Low beams are H1 55W
Parkers are D2R 35W
Fog lights are unknown at this stage
I'm having real trouble finding a replacement parker globe for my S2 with the afforementioned D2R fitment. The only info I can seem to find about D2R fitments is that they are normally on HID bulbs and I wouldn't have thought a parker would be a HID.
Has anyone else had to replace their parkers on a S2, and where have you bought your bulbs? I haven't been able to get them anywhere.
the front park light globes on the S2 are exactly the same in both HID and normal headlight models,small wedge type globes. you can get them in ANY parts shop.
Justin...
My fog light bulbs had been removed and the plugs cut off for compliance (crimp spade plugs work a treat to replace the plug). The bulbs for series 1 fog lights are H3C and a P.I.A. :D to source good ones anywhere except EBAY. Narva charge like $12 each for H3, but $50 for H3c. If you want to go for a narva or similar, purchase H3, and just ground them onto the chasis near the headlights, or just put spade plugs on the harness as I did and plug them into either the back of the H3c or to the extra wire that comes off a H3.
For information, if you want an affordable H3c, supercheap auto sells their own brand for about $12 each from memory, about a quarter of anywhere else.
And the S1 fog lights are awesome.. :)
i find that its better off to convert to HID system for the headlights. Works much better compared to the halogens. Im using the original headlight assembly. A direct plug in replacement. Dont need to use the fog light anymore.
So now I'm confused :)
AlexCim originally said:
S2
Parkers are D2R 35W
But then chook said the parkers are a G4 Wedge and the main bulbs (lo or hi beam) are D2R.
The Stagea lo beams are dissapointing to say the least, the fogs near useless and I'm in need of an upgrade of some sort.
I'm afraid I'll have to remove my front bar just to check and with my lack of expertise, I'm sure I'll damage something.
Can anyone confirm which is correct?
SK, did you end up doing anything with your lights? What did you do and how has it turned out?
for my lights
I used the stock housings
Bought a plug and plau HID HO.LO kit from a US vendor for 215 USD shipped
8000K brightness (too blue IMO now that i have it should have gotten 6000K
works outstanding
for my lights
works outstanding
600K would be the best to use on the road.
As far as i know stageas S1 uses H4 lo/hi all in one. Not too sure about the parkers though
  • 2 years later...
Well sorry for the thread revival, but I am a little confused as to whats what. Basically people say the Series 2 C34 low beam lights use H1 55w, yet i pulled mine out today, which are the stock xenon's( unless somebody changed the bulbs in japland) and the bulb had on it...D2r 35W.. Any ideas?
There defiantly not halogen bulbs, they are xenon, however in my previous car which had 6000k xenon's in it, i remember much greater visibility than what I currently have. Should i swap these bulbs over for some 6000k H1 55W ones?
Also could some please advise to what size bulb the Parker light is, as i would like to change it to a white light and get that horrible yellow out.
Dunno about series 2 but on my s1 lamp type is stamped on the plastic housing above the lights.
If by parker you mean the font indicator lights they are a single contact bayonet fitting 12v 21W.
you will get a bit for the stock set up if you want to sell it... its just matter of snipping the pos neg to the ballast... taking it and the globe out to sell... and re wiring the new ones back in... you will need some h1 globe holders tho... i have a set of stock xenon globes here D2R 35w with very good visability... you could jump on to the phillips website or somthing and get some 55w or somthing i spose???
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
