Vol 77 covers DC/B (May, 1993 - July, 2001) and DC5 (July, 2001 - present)
I've made a quick order for some of the popular ones, they should be arriving around the 1st of Dec. So once that arrives I'll make the order for the wierder models you guys ask for. It'll give you guys some time to sort out what you need.
So does this mean you don't want payment till the mags arrive in melb?
i'm ready to pay now :)
  • Replies 180
hmm... would rather payment now... but just got the guys in tokyo to send down 5 vol 89's, a vol 109, a vol 56, a vol 80, a vol 21 and a vol 50. I think batches of 10 is the magic number, so those were the first 10 requests.
I'll be sending PM's with payment details to all requests. Just the first 10 books will be recieved sooner than the others :)
kleenbeats... I think the Club Skyline mags have a couple of issues that concentrate on V35's. I've got all of em at home, so I'll have a quick browse thru and tell you which ones are relevant. I know there was one they released just after the V35 was introduced and it was chockers with info on em.
So far Mr Keets, Ronin 09 and kleenbeats miss out on the first shipment, but i'll get your books as soon as there's another batch of 10 ready to go.
Interloper, SNISMO, sloazr33, uLa32, blue_leaf, and 2630GTS your books should have been bought today and will be sent in the next couple of days. blue_leaf I got you the 2 you were definite about, if you want the others, let me know and I'll add em to the next batch.
Please put me down for Vol 101 - Fairlady Z No.3...
Ta :laugh:
there's also these books n dvd's for the fairlady z's...
http://www.zcar-owners.net/club/zmagazine.htm
there's also a new series like "Club Skyline" called "Only Z33 Fairlady Z" focussing on... well... Z33's :ninja: Issues 1 n 2 are out now.
let me know about any other v35 magazines availabe and I'll take them to.
Club Skyline Vol 19 has a good writeup on V35 tuning from engine to suspension mods. I can get the back issue of this.
The January Issue of RevSpeed has a writeup on VQ engine tuning, mostly Z33, but a lil bit on the V35 as well... you'll have to wait till this comes out at the shops.
GT-R Magazine Vol 40 (2001 June I think) is dedicated to the V35... but its a back issue, and I can't get it.
Also another back issue you can probably get off something like yahoo auctions is this one, Motorfan New Model News Flash Issue 284:
did you get my pm?
has the $ gone through?
got PM and payment :D
as did payments from sloazr33, uLa, 2630GTS and Ronin 09
cool cool, put me down for a copy of "Club Skyline Vol 19", I'd love that gtr magazine 40, I'll get searching
what do I owe yah?
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
