Having drama's with my radiator... bought the car with the current rad in it, its an r32 with RB20det etc etc, nothing outlandish at all. Somewhere along the lines someone has fitted this rad to it.
dont have a engine bay shot but basically the top rad hose crosses over under the cooler pipe and touches it... transferring all the heat in the process and the bottom rad crosses over and comes damn close to the crank pully.
its also been overheating on the track, so i dont think this rad is up to the job, mainly due to the top pipe location IMO, since its as thick if not thicker then a stock rad.
so anyway, i went to upgrade.. couldnt find a suitably priced stocker and several people told me to chuck a RB30 radiator in there, So i went and bought a good cond rad with top and bottom hose for 70 bucks.
now.. the bloody thing is too tall and the bonnet wont shut with it in the car, i was trail fitting it and the top and bottom hoses will fit perfectally but its too tall...
whats the go? do they fit with mods or not a chance in hell?
Cheers
Simon
https://www.sau.com.au/forums/topic/144973-radiator-woes/
They certainly look like they will push air back out the front of the radiator. That can't be good!
Anyway, dunno about the VL radiator, but perhaps you could stretch the budget to JustJap's aluminium radiator? I think they're around 350, and they fit like a stocker. A mate of mine put one in his 32 GTR, and it was fine apart from a bit of radiator shroud that needed to be chopped.
https://www.sau.com.au/forums/topic/144973-radiator-woes/#findComment-2707733
as the guys have said, make sure the blades are correct and the wiring, with most thermo's such as davies craig, depending on whether its a push or pull application, you may need to reverse the polarity of the motor as well as the blades.
generally though, getting a OEM thermo with a good shroud will work better then those types of fans. (will depend on how much room you have as to what will fit)
the factory clutch fan and shroud will work better then anything however, maybe fit original parts back on for reliability.
https://www.sau.com.au/forums/topic/144973-radiator-woes/#findComment-2707837
forget the fan, its wired to suck air through the radiator. Thats not the problem in question.
It's hard to... it really looks like the blades are angled to push air back forards through the radiator. If you've wired it to run backwards, then I guess you'll get a little bit of suction, but nowhere near as much as it could make. :)
Combined with no shroud, it's only sucking air through a small area of the radiator.
In any case, I think a stock setup would work much better than what you have, or as mentioned, an aftermarket direct-fit or GTR type. :)
https://www.sau.com.au/forums/topic/144973-radiator-woes/#findComment-2708267
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
