hey i just wanted to know the prices of a few things, as my birthday is comming up and want to mod my 32 a bit.
> price of a 4wd dyno tune
> getting it lowered 1.5 inch
>rolling the guards, as im am preety sure they will scrape.. the back wheels are 255 and they seem to stick out a bit.
>price of 3inch exhust from turbo back.
you can see some pics of what it looks like here.
also how much would i get for my wheels. they are 17's with a few scratches (not by me).
and how much for the rear wing. i dont know what type it is.
Thanks...
https://www.sau.com.au/forums/topic/14500-prices-for-r32-mods/
Guest Boxhead
yeh come on aybee, i know somepeople that wont need to be paid to take that thing off... that aside, can i have the wheels,
and those both aside, i would say depending on who you go to, the dyno time shoudl cost about $100 or more..
lowering it is a bit tricky to price, because you can just get some lowered springs for like $250ish a set, or you can get a set of second hand height adjustable suspension for $800 upwards...
the exhuast is also the same, you can go a 2nd hand jap unit, or a local new one, cat back should be $1000-1500 , plus front pipe and dump pipe( maybe get one form batbml, look in for sale section) and a highflow cat...
and im not sure about the rolling of the gaurds
Originally posted by GILTY
1) Sorry but in my opinion that wing has to go, go nude...
2) Your steering wheel is probably peeling like mine, but that wheel cover is not the answer (SORRY)
Yeh thats y i want it off... im not a fan of rice at all. what i have in mind for it will look realy nice. how it looks now is how it looked 5 weeks ago when i bought it.
the wheel cover is not on there anymore... ide rather put up with bits of the leather sticking to my hands.
I have exactly the same problem with my Steering Wheel, Apparently we can get them recovered for about $50 at any Auto-Retrimmer.
It is a pain in the ass to change the steering wheel because of the HICAS sensor, therefore retrimming the factory wheel is the best option. (And it is a pretty good wheel anyway)
I like your style, and for a stop-gap measure, just take the offending wing off and plug up the holes with wine red electrical tape. My boot still has white tape over the 4 holes, I just never seem to get around to getting them fixed. Have clutch to fix next weekend, and that is about 1K, so holes have to wait again!
Ive also got the problem with my steering wheel. Good to know someone can retrim it cheaply. I love the standard wheel.
I did have electrical tape on my boot due to my wing breaking but ive managed to fix the wing (the studs on one side were rusted through). It involved drilling two 12mm holes in the fibre glass and putting new bolts in, everything we tried just wouldnt work. This was the only realiable way. So now instead of having holes in the boot, ive got holes in the wing :D *sigh*
Of course I dont have the standard GTST wing (which sucks)... my car is fitted with a full GTR kit. Lovely jubbly.
Red17
i got a quote from a guy about taking the rear wing off..... $350! that to get the holes filled in and repainted tho.... still expensive. The wing has actually been glued down with poly urithane.
ne1 know a place that does good work that could take it off 4 me?... for a good price.
    • Turbo gods, some assistance and recommendations please I'm looking into a turbo kit for my 2.5 from MX5 Mania >>>>> https://mx5mania.com.au/products/copy-of-mx-5-nc-2-5-litre-engine-conversion-turbo-2005-2013 Power wise I would like about 200kw atw, and of course dose noises, apparently if you keep a stock 2.5 under around 200kwatw the engine will not hate life even when ragging on it a bit Max RPM on the 2.5 is around 6500rpm The turbo MX5 use is something around the disco potato size as  packaging room for the turbo is pretty limited, which will, I believe will give me my power goals and not have the turbo either under, or oversized, but the rear housing bit is confusing  It comes with either a 0.64 or 0.86 From my understanding, which so far is based off googling, so make of that what you will 0.64: spools faster = good Makes more EGT heat on boost = bad Less topend power than 0.86 = I'm only looking for 200 atw so that point may be mute????, I don't know, hence my questions  0.86: Spools a "little" slower = how much slower??? remembering 6500 is my max rpm Makes less EGT heat = good Makes a little more power up top = again, power goals is only around 200 Also, this is a street car, so there will not really be any long track sessions, in saying this I would want it so it was happy with at least 3 hot laps at Wakefield Park if the need arises  I already have a fancy pants triple pass radiator, and a oil cooler with thermostat will be getting installed as well Thanks for any information or recommendations you have 👍, and of course, the comments about me wasting money on drive in drive out modifications, or any other snide remarks about my manhood for owning a MX5 🤣
    • Tape some wool onto the vent then take it for a drive I did this to my reverse cowl and was instantly unhappy, as anything over about 60kph would have the wool enter the engine bay, thus just adding underbonnet pressure and stooging my coolant stack, it did let alot of heat out when stationary though, which really didn't help once the car was moving, with the reverse cowl you could watch the coolant temps cheap up the faster you went on the hwy, I assume it would be alot worse doing track day speed With the vented bonnet (just after the radiator and about 1/3 up the bonnet) on my old R33 the wool on the leading edge sat at about a 45° angle as air poured out of it From looking where your vents are, and their size, I believe you should be fine at speed and air should be evacuated from the engine bay, I think it will be a night and day difference when stuck in traffic though for removing the trapped heat, and not sitting there cooking when parked up after driving around... #convection  Post wool tuft pics and data for science  This beastie is one nice and unique rig, enjoy
    • It is possible to do this stuff for "cheap". But you need to be able to get deals on all the bigger items, and it really helps if you're fully capable of doing your own work. As soon as you're paying retail for new parts, or buying "kits" because you can't fabricate necessary bits and pieces, and if you really need someone else to take the reins of doing the work because you don't have the space/time/skills/confidence to  rip deep into the car and put it back together in a working fashions.....then you pay. And these days, pay means a lot of money. You'd think things would get cheaper, but they don't. They just seem to keep getting more and more expensive.
    • It’s almost the price of an engine build, you won’t have anything to bolt onto it though
    • Hopefully it's enough to help with the temps! I was also only shit stirring, regarding Murphy's Law basically. I've found, what ever spare parts I have, are the parts I don't break. Ever. Also have never had issues with oil/spinning bearings until I put oil pressure gauges on the car. 😛
