Hi All,
Thinking about my next car. I don't necessarily want a car with loads of power. Would like something that feels good to drive and every review I have read suggests that the boxster is a great drive.
You can get an early model boxster for around $50 large.
My only concerns would be the drop in power (the 2.5 litre boxster generates 150kw at the fly). Currently my skyline is generating around 155kw at the wheels so there may not be a huge difference as I am led to believe that Porsche tend to understate their power figures if anything . Also concerned about ongoing costs.
What do you guys think. Is there anyone who has driven one and how much more is ongoing maintenance than say the average car?
Cheers
  • Replies 163
I heard a term they use on the UK top gear show Porsche Boxster are a Poorman's Porsche.
Still if you have enough money to buy and maintan one i said why not its would be hell alot nice to drive than a R33.
If i had the money i would get one
This is actually a good time to buy them second hand with the new 987 boxsters been introduced for nearly two years now there are plenty 986s on the market. and they have depreciated to a point that you wont lose much money should you decide to sell the car later.
Important point to consider is try to look for a 3.2l boxster S, these are into the low 60k mark nowadays. with 185kw its performance should be similar to a turbo skyline.
Yeah, I'd be looking at a Boxster S or nothing. The standard just doesn't have the grunt.
I rented a Tiptronic Boxster about a year go for a few days. Great handling, average power, ratshit gearbox.
I was up in Cairns, and driving it up the side of the escarpment (with your typical mountain road switchbacks) was great. The brakes are amazing, and the car handles really well. Definitely more handling than power.
The thing is, do you want to brand name or do you want the driving experience? If its the latter and you can handle not making any power, give some serious thought to buying an NC MX5 soft top. It'll be a crapload cheaper to run, and just as much fun to drive. It'll also be brand new, or with demonstrator mileage.
I took a NC for a test drive, and to be honest there's almost nothing in it between the MX5 and the Boxster. There might be a bit more rear end grip in the Boxster, but there's not enough power to make that a major issue.
boxster = gheyyy
consider these cars...
BMW E39 540i = v8...:mad:
http://www.carsales.com.au/pls/carsales/...p;category_id=3
350z Track...221kw, with brembos! :);)
http://www.carsales.com.au/pls/carsales/...elected_model=0
rx-8...not a huge fan, but id get this over a boxster
04' liberty GT
with cars like these^^^.................screw the boxster
Hi All,
Cheers
Are you going to start a career as a hair stylist at the same time? :mad:
I wouldn't take that as gospel. That boxter is absolutely shagged. I used to work for that rental company and have driven that particular boxter extremely hard, just like everyone else who rented it. It doesn't get looked after as well as it should, I mean there isn't even a porsche dealer in cairns.
At the end of the day, its a rental car. I wouldn't judge any car I was looking at buying by driving a rental.
forget the boxter. if you've got $50 or $60K then there is only one car to be looking at if you want porsche. and that's 70s/80s 911. they are magic. they may not be as fast. or handle as well. but the noise, the look and the feel of them is hard to beat. be a man. do tha right thing.
911 all the way. like they say in risky business there is no substitute. (and yes I realise he wasn't driving a 911, but the point is clear).... as mud.
911.
911.
911.
or run the risk of me calling you a massive shirt lifter for life.
yeah, that's more like it. but only thing I'd change is skip the soft tops all together. go hard top, and thank me later. also switch the colour from white to black and we have a weiner. i mean winner.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
