Hi there, my skyline is a GTS25 non turbo. I never seen any model similar to mine before.
My mate had a look at my rear diff and he noticed that is it not the same a the GTSt. The model code for the rear diff is display inside the engine comparement and mine shows RC45
Read this
http://www.skylinesdownunder.co.nz/tech/mo...al_numbers.html
RC41 have 4.1:1 rear diff
RC43 have 4.3:1 rear diff
What is the difference between 4.1 and 4.3 handling and purpose?
Just like to ask around who have the same rear diff?
Is it an LSD version?
Thanx
https://www.sau.com.au/forums/topic/14502-model-code-for-rear-differential-r32/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
