Anneal=use a gas torch [or your mums gas stove], dangle the copper washer on a bit of thin tie wire, let it get cherry red with the heat, then dunk it in a cup of cold water. This process softens the copper and restores its sealing properties. A metallurgist will tell you that the heating and rapid cooling re-aligns the crystal structure in the metal.
It is [very] good practise to do this with all copper washers/gaskets before using them, even new ones should be done. The manufacture processes [metal rollers and metal stamps] tend to work harden the metal. Added to this the washers could have been bumped around when shipped out to the warehouse where they laid around for months in the atmosphere absorbing oxygen etc - this also adds to the hardness/brittleness. Annealing fixes all this up. Older cars and motorcycles [pre 1960's] regularly used copper head gaskets, manifold gaskets, washers etc, these gaskets were annealed and used again and again with every rebuild and worked fine.
As a test, try to bend your copper washer before you anneal and then try it again after you have annealed. Notice the difference? Afterwards the copper is heaps softer and ready to use.
The only time I would not recommend re using your copper washers and gaskets is if they have been used that many times that they are now too thin to take up the space.
Actually 'annealing' is a process involving slow cooling following heating. Rapid quenching can induce stresses due to dimensional changes, but in small parts it will hardly matter. A metallurgist will tell you that, with copper alloys at least, annealing relieves the effect of dislocation motion and 'pile-up', which ultimately results in the work hardening effect and, at the extreme, fracture. Dislocations are defects in the crystal lattice.
Of course what annealing won't do is restore dimensions such as thickness (eg compression of a copper head gasket), which is why it's not an 'indefinate' process.
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
