Hi guys,
I've got quotes for my front DBA rotors (32gtr), the 4000 series slot kanga all pawn something for $240 each, is it good?
Also Bendix Ultimate for $120 a set front and rear.
Thanks
West :D
For the price of those pads i would go racebrakes RB74's
I just got RDA gold slotted and dimpled, throught these forums, for a very decent price but I am not allowed to quote pricing in here... check user rs73's group buy in the classified section... however I am not sure how they compare in performance to the DBA's...
I run RDA slotted street rotors. I've heard people saying that they have seen them crack through the grooves as they go to the very outside edge. I've abused these for close to 15000km's and have had no problems. I've seen the DBA ones crack, but that was due to other influences instead of regular driving.
I've run RB74's on the street as well as track use. I don't rate them very highly. They are fine for a few fast laps, but then they seem to give you a spongy pedal. This was with Motol RBF600 and braided lines with rebuilt calipers. I managed to split the friction material which then broke away from the backing plate. They also got very crumbly. They also chew up your rotors pretty good when they are cold.
I spoke to The guys at race brakes and they told be that I was over heating them too much. My understanding was that they were a race pad suitable up to 650deg F. The pads also warped. The centre section of the friction material was starting to scallop out. I was aware that this might happen when they drop below 50%, but these were up around the 75%.
Racebrakes Comp 2 pads are awesome. I've never had any problems with them. They seem to last and don't fall to bits. Great bite, even when cold.
yeah i never recommended them for the track. There are better pads out there.
But track or street, they are a better pad than the bendix ultimates at that price range
I've just pad $120 for bendix Ultimates. The RB74's I'm looking at $185. I'd prefer the Ultimates. Better cold bite, less noise, less dust. Don't chew out rotors when cold.etc
What pads do you think are better for the track??? Before we head dowm the Green/Black stuff pads, they out-gas pretty fast and you end up with glazed rotors pretty quickly. I also cannot use them on my slotted rotors as the outgassing fills up the slots, rendering them useless! For $300+ pr, I'd like something that was substancially better.
Get a price on the ultimates at repco Khoa. I got mine for $100 a pair, after just being quoted $130 at autobarn. I went to repco asked for a price, they asked me if I had any other quotes...I said autobarn said $120.
Repco said, RRP is $144 on the computer, so i'll do em for $100 a set .
Justin went to his repco the next day and told them that I got them for $100 a set, so they did his for $90 :kiss:
They've also beaten SK's GB prices on all the whiteline stuff so far, and thats without me even trying to get the price down...just ask for a quote, and they were cheaper :huh:
WTF, awesome Dezz man, shall do. Thanks.
hmm i paid 120 for the rb74's, good cold bite and no noise whatsoever, which is what turned me off the ultimates aswell.
I use project mu pads for hard braking, they are awesome.
Ultimates are farking squeaky!
i've had them for the last 2000km and i was at a point considering changing them back to stock street pads :)
I got my DBA slotted through my mechanic for $214 each ;)
i've got ultimates on my commodore and never had any problems with squeaking. If they make noise i woud say they haven't been bedded in properley. do get alot of dust with them though......
I always thought rda's were the better ones as the dba's crack.....
DBA4926 is for 32gtr.
This is the 4000 series with slot.
Also i've managed to find them for $200 each. Still searching.
Got the pricing in for mine today. I think I will go the 4000's instead of the 5000's as the cost difference is significant and this car is eating $$ at the moment :(
Going to go for Ferodo DS2500 pads
Interestingly, I learnt today, A good brake fluid is as important as good pads. Always thought fluid was fluid but if you have great brakes but crap fluid that boils, it defeats the object of the kick ass brakes in the first place.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
