Turbo Timers
Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
I don't know, honestly. Easier to just use a CAN wideband with the Haltech so you can get the ECU to control the wideband in the manner described. -
Update time! The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago. I also finally got the rear lip painted and fitted. I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy. Close out with some nice pictures of the cars and a sneak peek of what's next.
Once you learn it all, you find you do the job once. But this is the best way to learn, as you won't forget the lessons
