grab a jack & block of wood and put the wood underneath the crank pulley and jack it up a bit to tilt the engine back. also undo the top bolt on the starter motor first, caus ull need to use ur fingers to unscrew it
bell housing bolts, with the motor tilted back, grab all the long extensions u can find and put a uni-joint on b4 the socket and u should be able to undo them that way.
I've done this by myself on the garage floor, elapsed time from getting it out to getting back in ended up being about two weeks....(long story) - it wont take you anyway near that long, but it will probably be a complete BIATCH.
Anyway i got some good tips from here so try searching for past threads on the same topic. From what i can remember,
- You'll need 2 x 500mm extentions to get the top bolt(s) out. I used some electical tape on the uni joint to stop the socket from flopping down, but still offer some flexibility.
- Take the front pipe off
- Stubby ratchet ring spanners are you freinds
- If you're changing the clutch dont forget to get a clutch aligning tool to make it easy
- I had two trolley jacks and wanted a third
- Dont forget to block the hose that connects to the rear of the box, or you'll loose all the fluid from the resevoir down
- When you're putting it back on, you have to push the box up rotated (cant remember which way) then when you've got it in position rotate it back - i couldnt get it back in if i tried to just lift it straight up.
hope some of that helps,
Kot
Edited by MrKotter
I did mine on a hoist and it was a piece of piss. The starter bolts are a little annoying though! Im sure without the hoist it will be a little trickier. See if you can get a cradle for a trolley jack to carry the transmission..
I've done this a few times now and can get one out in about 1.5 hours if it has been pulled out recently.
The first thing you should do is borrow an air compressor and then go and by a supercheap air rachet for around $40. This will become your best friend. This will save you cutting up hands and about 2 hours!
A couple jacks.
You'll need a stubby 14mm spanner for the starter motor. Its easy to access with one of these.
You may possibly need an allen key that fits a 1/2 inch breaker bar to undo the tail shaft. These can be really tight.
For the top bolts you don't need to jack the engine as most people say. Just by undoing the rear crossmember your can get in there with extensions and a socket. Also if I remember right you can reach across the top of the g/box from the passenger side by hand to undo the drivers side bolt once its cracked.
Remember though to leave some bolts in the bottom of the bell housing to stop the g/box sliding off.
Leave the rear crossmember bolted to the g/box to stop it spining around on removal.
One thing to remember is that the transfer case is seperate to the g/box and they use different oils.
Also for a cheap and easy clutch aligning tool you can use a pen with sticky tape wrapped around it if your desperate. I've always done this and had no problems.
Hope this helps.
I have done this many times by myself. Just be carefull.
Well the box is out - damn heavy thing it is!
I removed the gearbox xmember and lowered the box down with a jack, this gave me enough space to rear the top bellhousing bolts with my 1/4 drive extension bars. The allen key bolts on the tail shaft were very tight, extension bar over the top sorts it out.
Interestingly no fluid seeped out of the hydrualics upon removing it from the transfer case.. any ideas why? Hopefully the pump is not stuffed.
Twisted and bought the box down slowly, was stupidly heavy! I had a mate helping me, I'd recommend having a 3rd person no doubt.
Now to change the transfer case and whack her back in there.. *ughh*
holy shit theres abit to it. im so glad my mates a good mechanic. not long till ill attempt it, sounds like a case of the right tools and abit of time will see you through.
good info everyone will help us heaps
Very little should come out of the rear of the box but if you dont block the pipe that comes from the rear it will keep coming out .
Don't forget to bleed the sydtem when you put the box back in, i've seen plenty with air in them after the had a clutch change
Turned out Nissan gave me the wrong size roll pin. *insert cursing here*. Anyways new pin sorted, box is all nice and clean and ready to go back in this week. I have never driven the car with ATTESSA functioning, shall be interesting :)
Edited by Remix-
Turned out Nissan gave me the wrong size roll pin. *insert cursing here*. Anyways new pin sorted, box is all nice and clean and ready to go back in this week. I have never driven the car with ATTESSA functioning, shall be interesting :D
good stuff.
few tips. dont use grease on the thrust bearing or the input shaft caus it can stuff ur clutch, instead use graphite powder. also put a little dab of grease on ur pivot ball to stop any squeaking
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
