One of my HKS 2530's crapped out so in need of some replacement turbo's as I can't rebuilt my single turbo due to the turbine being damaged...unfortunatey the other one is brand new.
I have seen very good reports on the Apexi AX series with p21 housing, which is said to have less lag than 2530's and make more power at less boost.
I haven't seen any results of the GTRS apart from on a 2.8ltr
Can anyone shed some light on these...
GTRS have a larger lag than the 2530's.
You also cannot run two different turbo's ....so if you are looking to replace the one .....you have no choice but to buy a single 2530 or -5 in Garret as they go by.
A couple of options here depending on what else is damaged on that HKS GT2530 . IF its turbine housing is was not damaged a reasonably cheap way to get a virtually new turbo would be to buy the Garrett -5 or which ever is the 2530 equal cartridge (CHRA) and swap compressor wheels . The rest of the cartridge is the same as a 2530 (same turbine and bearing/housing assembly) . Fit the 2530's 63 trim compressor , balance and refit the 2530's housings . GCG or Garrett should be able to do this for you .
Cheers A .
  DiRTgarage said:
make sure you find the reason for the failure and fix before you fit the new one....be sure the oil lines are clear of blockages (this is what killed ours and several others)
You beat me to it - definately find out the root cause of the failure and certainly check the other terb carefully before assuming it's OK as well.
all valid points, just to clear a few things up tho.
the turbine is damaged meaning it needs a new shaft, mine is a 707160-21 meaning it is an obsolete part.
I stated I will be replacing "turbo's" (plural) so no I won't be trying any new sequential setup, lol
The -5 is smaller by .5mm than the 2530 so is automatically out for me.
The turbo was on its way out already however I will definitely check the oil feed, from what i can see 22psi with above average shaft play caused imbalance and excessive wear
A single 2530 will cost me $2300, I would rather sell my new 2530 and the housings from the stuffed turbo to purchase and improved set. I am very very keen on the Apexi AX series, I have seen very good results on every car they were fitted. 1 bar ~400rpm earlier than a 2530 and 60ps more at the same boost. The AIRICK design is far advanced over HKS. The same compressor size is more efficient- more flow and less heat. Nengun are adding them to there catalogue for me.
I thought the -5's are the same as the 2530.....maybe they are the old type ......or they have been modified.
Find out why this happened then replace them both.........
The Replacement Turbo's (-5)should only cost you 2500 for the pair...
Who is selling one for 2300?
Anyway good luck with your choice.
For the record the complete GT2530 may not be available but its only unique part was its 63 trim 60mm GT30 compressor . If you bought the -5 cartridge its should be identical to the 2530's except for a slightly smaller trim (62) and tip height compressor . Its turbine and shaft IS the same . Buy , swap comp wheels , balance , done .
Its not impossible that the -5 cartridges may suit you better than the 2530's if they were a tad lazy for you . The GT2530 is a HKS optioned Garrett GT2860R and an older one at that .
Cheers A .
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
