One of my HKS 2530's crapped out so in need of some replacement turbo's as I can't rebuilt my single turbo due to the turbine being damaged...unfortunatey the other one is brand new.
I have seen very good reports on the Apexi AX series with p21 housing, which is said to have less lag than 2530's and make more power at less boost.
I haven't seen any results of the GTRS apart from on a 2.8ltr
Can anyone shed some light on these...
GTRS have a larger lag than the 2530's.
You also cannot run two different turbo's ....so if you are looking to replace the one .....you have no choice but to buy a single 2530 or -5 in Garret as they go by.
A couple of options here depending on what else is damaged on that HKS GT2530 . IF its turbine housing is was not damaged a reasonably cheap way to get a virtually new turbo would be to buy the Garrett -5 or which ever is the 2530 equal cartridge (CHRA) and swap compressor wheels . The rest of the cartridge is the same as a 2530 (same turbine and bearing/housing assembly) . Fit the 2530's 63 trim compressor , balance and refit the 2530's housings . GCG or Garrett should be able to do this for you .
Cheers A .
make sure you find the reason for the failure and fix before you fit the new one....be sure the oil lines are clear of blockages (this is what killed ours and several others)
You beat me to it - definately find out the root cause of the failure and certainly check the other terb carefully before assuming it's OK as well.
all valid points, just to clear a few things up tho.
the turbine is damaged meaning it needs a new shaft, mine is a 707160-21 meaning it is an obsolete part.
I stated I will be replacing "turbo's" (plural) so no I won't be trying any new sequential setup, lol
The -5 is smaller by .5mm than the 2530 so is automatically out for me.
The turbo was on its way out already however I will definitely check the oil feed, from what i can see 22psi with above average shaft play caused imbalance and excessive wear
A single 2530 will cost me $2300, I would rather sell my new 2530 and the housings from the stuffed turbo to purchase and improved set. I am very very keen on the Apexi AX series, I have seen very good results on every car they were fitted. 1 bar ~400rpm earlier than a 2530 and 60ps more at the same boost. The AIRICK design is far advanced over HKS. The same compressor size is more efficient- more flow and less heat. Nengun are adding them to there catalogue for me.
I thought the -5's are the same as the 2530.....maybe they are the old type ......or they have been modified.
Find out why this happened then replace them both.........
The Replacement Turbo's (-5)should only cost you 2500 for the pair...
Who is selling one for 2300?
Anyway good luck with your choice.
For the record the complete GT2530 may not be available but its only unique part was its 63 trim 60mm GT30 compressor . If you bought the -5 cartridge its should be identical to the 2530's except for a slightly smaller trim (62) and tip height compressor . Its turbine and shaft IS the same . Buy , swap comp wheels , balance , done .
Its not impossible that the -5 cartridges may suit you better than the 2530's if they were a tad lazy for you . The GT2530 is a HKS optioned Garrett GT2860R and an older one at that .
Cheers A .
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
